17286 Discussions
Intel Extreme Tuning Utility do not install
NPres3
Hello i have a problem with the Intel Extreme Tuning Utility software when I try to install it in the end gives me this error
My CPU is an i5 6300HQ and a laptop Asus Rog GL552VW-DM149
what can I do?
Hello Nikola87:
Thank you very much for posting the image above.
Based on it, the problem seems to be related to the privileges to start system services, in this case, you just to run the PC as administrator and you should be able to install the tool, just right click on the tool and you will see the option to do that.
Alberto
