- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Everytime I launch Intel XTU it gets stuck on splash screen, and after 15-20 minutes crashes my computer, Ive tried resetting everything on my computer and reinstalling and that worked last time, but this isnt feasible to keep having to do this every month, is there another fix?
Specs:
Processor: Intel(R) Core(TM) i9-13900KS 3.20 GHz
Windows 10 Home 22H2
OS build: 19045.4717
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hey, its been 5 days and I've gotten no replies, is there anyone that can help with this problem as it is still happening
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
I will be working with you to find a lasting solution to your concern. Kindly provide the following, as I will need this to provide you viable suggestions:
1. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
2. Do you have other overclocking utilities or system management utilities like the one from your motherboard manufacturer that is installed on the system?
3. If you say resetting the system, does it mean resetting Windows?
Alfred S
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have an MSI motherboard so i do have the MSI Center application, however I do not use it to overclock my system at all.
As for resetting, Ive flashed my bios to the most recent msi update, ive uninstalled and reinstalled intel xtu, both with and without removing profiles, and I have also hard reset my computer wiping all data besides windows, which i then reinstalled
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Were you able to figure out anything wrong from the SSU Scan text file?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hey, I'd prefer not to have to RMA this CPU like the other guy is saying because at that point I'd honestly rather just never buy an intel CPU again, is there any other way to fix this problem?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
13900K , you got a broken degrading CPU, RMA it, the process will be painful until Intel improves the RMA process.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
We are currently investigating your concern and we would need to get advanced logs from your Intel Extreme Tuning Utility. Due to the sensitivity of the instructions and the log that it generates, we will send it via email. We will also wait for your reply via email.
While we are investigating, are you able to try disabling the MSI Center application temporarily, to see if the problem will not happen when that is disabled?
Alfred S
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
I wanted to check if you had the chance to read the questions that we posted and the instructions that we sent via email. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Currently out of town for work, ill try to do the things listed on the email over the weekend because I wont be back until late Friday night
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I actually had my friend follow the steps provided, were having problems with the following steps:
- Restart the XTU Service, or restart the computer.
- Start XTU and reproduce issue
- Share new XtuCore logs available in C:\ProgramDate\Intel\Intel Extreme Tuning Utility\Logs. Specifically the XtuCore file after the issue was reproduced, which will now include additional information details [ INFO ]
We cant find the file location mentioned above, and no error pops up because its literally still on the splash screen, so I'm not sure what error code I can provide for you
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
Thank you for quickly carrying out our last instructions.
Kindly try to see if your “Show Hidden Files” option is activated.
If it is activated, kindly provide us application event logs from Event Viewer. We will send an email, so you can reply with the logs there.
Alfred S
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
I wanted to check if you had the chance to read the suggestion that we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hypeddolphins,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
