17248 Discussions
Intel Processor ID utility shows Xeon 5130 as not VT?
On my HP xw6400 with Xeon 5130 the Intel Processor ID Utility shows the processors as
Virtual Technology No
I have the latest BIOS, 2.38, and VT is enabled in the BIOS
What am I missing here?
Techspec's shows that the cpu has vt-x
http://ark.intel.com/products/27216/Intel-Xeon-Processor-5130-(4M-Cache-2_00-GHz-1333-MHz-FSB http://ark.intel.com/products/27216/Intel-Xeon-Processor-5130-(4M-Cache-2_00-GHz-1333-MHz-FSB)
So it should support it.
Snoop around in your bios to see if there is not a other option hidden somewhere.
These HP biosses are a crime to understand sometimes.
Also i would take a look @ this :http://communities.vmware.com/message/705601 http://communities.vmware.com/message/705601
if its still not working i would contact hp about this.
Hi Nessuno
Thanks for that.
Yes I looked everywhere in BIOS, but found no more hidden Options - its a fairly new (compared with the age of the xw6400!) BIOS ( 12/2010 ) and has a VT Enable so I expected it to work.....
But I think I may have stumbled on the answer, which I record below in case anyone else hits the problem....
I should have given more info in the original mail - the workstation/server is running W2008 AND HYPER-V - I believe this combination disrupst both the Intel Processor ID utility and the 'old' VMware 64 bit Compatability check, because they were both working under an o/s that has virtualisation already enabled....
So once I found the vmware cpu identification utility at http://www.vmware.com/uk/support/shared_utilities.html http://www.vmware.com/uk/support/shared_utilities.html which is an iso and does not run under Windows etc. - it gave the correct answers.
Moral of the story - don't try and mix your virtrualisations.
Hope that helps.
