17492 Discussions
Intel(R) Dynamic Tuning Technology Updater Component (error 28)
Inspiro
Hello!
I am having trouble with the Intel(R) Dynamic Tuning Technology Updater Component. It shows error 28 in the Device Manager. It seems it is lacking a driver. Can you help me with information on where to find a proper driver? I have an HP Spectre 360. Thanks!
pressed_for_time
Valued Contributor III
The HP Support Assistant for PC should provide any missing drivers as well as updating any others that may need it, see the HP Support Assistant  page. If that does not work, the HP Laptop drivers page is here.  You could also raise this as a question with the HP Community or ask HP directly for advice through this page .
Inspiro
Thank you very much!
boraasid
احتاج تثبيت التعريف Intel(R) Dynamic Tuning Technology Updater Component
Intel(R) Dynamic Tuning Technology Updater Component  ( كود 28)
المعالج 13th Gen Intel(R) Core(TM) i5-13420H (2.10 GHz)
ذاكرة RAM المثبتة ‏‏16.0 غيغابايت (‏‏15.7 غيغابايت مستخدم)
نوع النظام نظام تشغيل بإصدار 64 بت ومعالج يستند إلى x64
