17052 Discussions
Intel Skylake CPU power consumption comparison
AZwen
I've recently decided to buy a intel skylake cpu for my home automation server, where I have narrowed to the following CPU's to choose from:
Intel® Pentium® Processor G4400T (3M Cache, 2.90 GHz)
Intel® Pentium® Processor G4400 (3M Cache, 3.30 GHz)
Intel® Core™ i3-6300T Processor (4M Cache, 3.30 GHz)
Intel® Core™ i3-6300 Processor (4M Cache, 3.80 GHz)
Intel® Core™ i5-6600T Processor (6M Cache, up to 3.50 GHz)
Intel® Core™ i5-6600 Processor (6M Cache, up to 3.90 GHz)
Intel® Core™ i7-6700T Processor (8M Cache, up to 3.60 GHz)
Intel® Core™ i7-6700 Processor (8M Cache, up to 4.00 GHz)
My server should be powerful for computer vision tasks and energy saving when it is not processing. At the same time it should be as cheap as possible (with a trade-off for computation power, which I have to decide).
The one question I would like to get answered is the idle power consumption for each of these CPU's (no dedicated graphics card will be included) and the power consumption at full load for the same conditions. As operating system I would use whether debian, arch linux, slackware, centos or linux mint. I couldnt find a site which shows measured values of idle power consumption of those cpu's. An estimation would be an alternative, if there are no comparable measurements yet.
Thanks in advance!
AP16
Valued Contributor III
Unfortunately, Intel do not publish max TDP for C1/E state of 6-gen CPU, so it is hard to tell about idle power drain. Maximum values you can see at http://ark.intel.com/products/codename/37572/Skylake Products (Formerly Skylake) (TDP column)
AZwen
Hi JFFulcrum,
thank you for your response. Is there a comparison of 5th gen CPU idle power consumptions? I think the differences may be very low, but It would be very nice for me to see measured values instead of something like (TDP: 45W). Thats not enough information for me.
AP16
For gen5 CPUs was declared 23W max power in C1/E state. Although the 5th gen consists from only 4C CPUs, so we have no data for lower core counts. Measured values of CPU only power are not available, there are measures of whole systems, check the http://techreport.com/ http://techreport.com/ reviews for example.
AZwen
Hi JFFulcrum,
Thanks for the response! I wasn't aware of the absence of 5th gen i3 desktop processors. However, I think the i3 6100-6300 or i3 6100T-6300T are the ones that fit my needs the most. I was asking for measurements - that would have been the ideal case, but since the processors are pretty new, I guess there is not so much practical information available yet. I would be satisfied already, if I could get a little more information about the i3, which I couldnt really find on the internet (at least I'm not very confident about the answers I have found so far).
1.) Is the idle power consumption of i.e. i3-6100 and i3-6100T (T - vs. non-T versions in general) different? If so, by how much?
2.) Is the estimated idle power consumption of i3-6100 or 6300 somewhere around 5W?
The reason for this thread is, that I want a low power consumption in idle and I've read somewhere, that some 4th gen i3 need 25W in idle and in some other forum I've read, that the idle power consumption of current intel desktop CPU's is < 5W throughout all models (i3, i3T, i5, i5T, i7, i7T). If someone in this forum has a very high confidence (or has already measured it or seen some measurements on the web), that the i3-6300 (or 6100) requires less than 5W or similar in idle, I'm going to buy it asap. If not, I will take a closer look at the i3-6100T.
Thank you for your contributions.
AP16
Probably yes, for 4-gen CPUs for low-power (like T) SKUs, max C1/E values was lower by 5-7 W comparing with base models.
AZwen
Thank you! Thats too bad. I hope they are almost identical for 6th gen i3 CPUs.
MKunt
Any new information on this? If the idle power consumption would be the same it wouldn't less matter if it is a T model or not. Which one did you buy? What are you results?
YMukh
The following system consumes 12-14 watt on idle and under light load:
cpu: Intel i7-6700t
motherboard: Supermicro x11ssz-qf
ram: Crucial DDR4 2133 CT8G4DFD8213
ssd: Samsung 850 Evo
psu: SeaSonic SS-400FL2
cpu cooler: Intel E97379 0.17A Foxconn
EstebanA_C_Intel
Hello All:
Thank you for contacting Intel Communities.
I understand that you would like to get the power consumption for some processors.
A chart for the power used in the different states of the processor (idle, full load, etc) is not available right now.
This is because depending on the usage the processor is needing, the power consumption is needed.
Now, in order to better understand the power management for the processors, my recommendation would be to check the datasheet for the processor.
Here you can find this information for Skylake or 6th Gen processors:
http://www.intel.com/content/www/us/en/processors/core/desktop-6th-gen-core-family-datasheet-vol-1.html 6th Generation Intel® Core™ Processor Family Datasheet, Vol. 1
Also, Intel has some applications that can monitor the power usage.
https://software.intel.com/en-us/articles/intel-power-gadget-20 Intel® Power Gadget | Intel® Developer Zone
https://software.intel.com/en-us/blogs/2013/06/18/measuring-application-power-consumption-on-linux-operating-system Measuring application power consumption on the Linux* operating system | Intel® Developer Zone
Esteban C
AP16
Esteban, is there a reason for exclusion from datasheet of 6rd gen Cores TDP values for C1E state (Table 5.3)? Most systems never reach deeper states for whole their productive life, so C1E value is a practical knowledge needed for system power planning.
YMukh
I've been trying to find this exact information! How do Skylake processors compare in power consumption in idle states? Would there be any difference between Core and Xeon e3-1200 v5 processors in idle power consumption?
YMukh
It seems that idle processor consumption is the SAME for all Skylake i7 chips: 14w.
Above I listed my test system with 6700T processor. In this article [ http://blog.codinghorror.com/ Coding Horrorhttp://blog.codinghorror.com/to-ecc-or-not-to-ecc/ , To ECC or Not To ECC ] an identical system but with 6700K processor is documented to have the same idle power consumption. I would have gone with a regular chip (6700 or 6700k), had I had this information earlier.
EstebanA_C_Intel
Hello:
Thank you ymukhin for the information provided related to the power usage on these units.
Esteban C
MKunt
On the linked blog I only saw a 6100T with 10W power consumption in idle state (but for the complete system). It seems that there isn't a big difference between the 6100T, 6500T and 6700T. Taken your system as base you can say +2W for each higher class CPU.
You are saying that the regular versions (TDP 65W+) are having a similar power consumption in idle state? I only read in an article of tomshardware, that the 6700K only needs 5W in idle state (but only the CPU). What sense does the T models make except a higher price and lower power? Yes, under load you have a lower power consumption, but also reduced CPU power compared to the regular models. If the CPU has finished it can go faster into idle state. What advantages does the T models still have?
YMukh
Here is a shameless quote from the blog referenced above (link has been updated too):
i7-6700k Skylake 4.0 Ghz / 4.2 Ghz quad-core ($370)
SuperMicro X11SSZ-QF-O mobo ($230)
64 GB DDR4-2133 ($520)
CSE-111LT-330CB 1U chassis ($215)
Samsung 850 Pro 1TB SSD ×2 ($886)
1U Heatsink ($20) 14w idle, 81w BurnP6 load
EstebanA_C_Intel
Hello:
I was able to find this article that has some information regarding power consumption that may assist you.
http://overclocking.guide/skylake-overclocking-power-consumption-and-voltage-scaling/ Skylake – Overclocking – Power Consumption and Voltage Scaling | Overclocking.Guide
Esteban C
