16964 Discussions
Intel XTU application stress test doesn't work on 13600kf
Aryan-31
The stress test runs for set time i.e 5 mins or 15mins without any load on cpu.
Cpu utilisation is 0%.
Screenshot attached
Specs:
13600kf with Air Cooler:- Cooler Master Stealth MA624
asus z790-P D4
TeamGroup 3600mhz ddr4 CL14
Msi Gaming X Trio 3080 Ti
850W GOLD NZXT PSU
Aryan-31
Logs attached.
This is generated by new Xtu installed from above provided link
Jocelyn_Intel
Hello, @Aryan-31
I hope you are doing better
Thank you for your reply and the information provided.
Let me investigate this issue. As soon as I have any updates, I will get back to you.
Jocelyn M.
Jocelyn_Intel
Thank you for your time.
We are still investigating this issue. However, there are a couple of questions we need to confirm so we can have more information and do a better research about this issue:
  1. When running the IPDT stress test (which passed), can we get a screenshot of Windows CPU usage, similar to XTU?
  2. When completing the XTU Memory tress test, does it show "Pass" results?
  3. Do you see the same results when running the CPU stress test, vs. the Memory stress test?
Jocelyn M.
Aryan-31
2. XTU memory stress test PASS without actual work done
3. Yes same issue with memory test or core stress test
Jocelyn_Intel
Hello, @Aryan-31
I hope you are great.
I am checking this thread and I would like to know if you were able to perform the steps in my previous post.
Jocelyn M.
Jocelyn_Intel
Hello, @Aryan-31
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
Aryan-31
I have replied above.
Also the issue is open for months with no solution
