17151 Discussions
Intel i3 core 2310M. Overheating, load 100%, Frequency 0,82Ghz, 1 active core.
BBill10
Please Help!!
Intel i3 core 2310M. The processor pass all the diagnostics test and also the stress test. But it has the half performance of the correct. I cannot work.
Because I believe 1 image equals 1000 words, I display some images which may clarify this strange issue:
Image 1) 0.81GHz, 1 active core
Image 2) The processor passes the stress test:
Image 3) Windows settings are correct:
Image 4) The processor passed ALL the stets of IPDT. The CPU frequency test displays the correct frequency (2.10 Ghz)
BBill10
Finally, the problem solved with the command:
bcdedit /debug off
BBill10
I want to add that the temperature of the processor remains constantly stable at 79-80C .. Also the core C0 has always temparture 3 C above the core C1
BBill10
I want to add that in safe mode the processor work with the correct characteristics (2.10 Ghz , 2 cores , temperature 36 C, about 15% load).
Also, I have hardware problem with the Ethernet connector.
BBill10
bcdedit /debug off
Hello, billst:
Thank you for taking the time to share your outcome, I am glad to hear that you were able to fix the issue. I will mark your previous answer as the correct one.
If you need further assistance let us know.
Amy.
