Ankündigungen
17258 Diskussionen
Intel i7-840qm with intel turbo boost
slao2
Einsteiger
7.506Aufrufe
Hi everyone. I'm using Intel I7-840QM as cpu on my alienware m15x. The intel turbo boost tecnology working fine with AC adapter (I can see from intel turbo boost monitor that frequency is going from 1.86GHz to 2.96GHz), but when I'm using my laptop with battery it doesn't work.
I tried to set everything about power saving (Best perfomance option) and set cpu frequency at the top 100% but nothing change. What else?
1 Lösung
Allan_J_Intel1
Mitarbeiter
6.225Aufrufe
If possible access the BIOS and disable Enhanced Intel® SpeedStep® Technology (EIST).
Allan.
Lösung in ursprünglichem Beitrag anzeigen
6 Antworten
Allan_J_Intel1
Mitarbeiter
6.226Aufrufe
Allan.
slao2
Einsteiger
6.224Aufrufe
Thanks for your reply. Tried to disable it but when intel turbo monitor run it gave an error "enable intel turbo boost tecnology" and doesn't work
mumai
Einsteiger
6.224Aufrufe
i have i73635qm
its turbo boost works fine when pluged in charger
but did not works on battery
even i have set every thing to 100%
pleaseeee help me
Allan_J_Intel1
Mitarbeiter
6.225Aufrufe
I find this as expected behavior, when using battery the laptop will save power and turbo boost will be disabled.
Allan.
mumai
Einsteiger
6.224Aufrufe
but not every laptop has this function
(i have seen alot of laptops whose turbo boost works on both ac and battery)
i really want to run turbo boost at battery
please tell me how to do this?
i have chacked bios but nothing happens
i have enabled and disabled things again and again mentioned any place in internet but could not able to run turbo boost on battery.
help me to solve my problem
thanks for your reply
Allan_J_Intel1
Mitarbeiter
6.224Aufrufe
Turbo boost is a feature that is controlled by the computer BIOS; if there is no option to control turbo boost when running on batteries, I am afraid this will be feasible.
Allan.
Antworten
