Is it normal?
MarioH73
hi everyone.
I have an i7 8700 and the motherboard is a msi z370A pro with a Quatro p4000. Then shouldn't I just have 2 monitors on the p4000 and my 3rd one via the motherboard?
In my case it doesn't see the third monitor, either that is correct or I am doing something wrong. if this is so what?
AlHill
Check the video settings in the bios.
Update your bios.
Regarding "Is it normal",
“The only glory most of us have to hope for is the glory of being normal.”  Katherine Fullerton Gerould
n_scott_pearson
In Desktop systems, by default, when a discrete, add-in graphics (dGFX) card is recognized, the processor's internal graphics (iGFX) engine is automatically disabled. To fix this, you need to adjust the BIOS Configuration to indicate that the iGFX engine should remain enabled.
Hope this helps,
