16964 Discussions
Issues with i7-10700k boost
JVele4
When i fist recieved the i7-10700k i remember it boosting by itself to 5.1 ghz now it only goes up to 4.7ghz is there a way to get it to go back to 5.1ghz?
n_scott_pearson
First of all, the achievable Core frequency gets lower as the number of busy Cores goes higher. The highest Core frequency is going to be seen when only a single Core is busy. Typically, if you are trying to monitor the boosting that is taking place, you are introducing a multi-core load and this is going to result in the achieveable boost rate being lower.
