LGA775 broken pin
Hello all, i have a question about a motherboard with a broken pin which seems to be working fine but I need and Intel EXPERT here to resolve this..... The pin is half broken, only the the ball at the end. The pin number is A23 which is labeled as "VCCA - A23 - Power/Other" in the Q6000 series pin layout. I need to know if this pin is critical for the mobo not frying the CPU, because the system seems to work fine.
