17486 Discussions
Low CPU frequency on Intel i9 when running a python program
Jacalyn
CPU frequency can drops below 1GHz when running a python program. Before running, its' up to 3.8GHz. It seems this behavior only exists on i9, and not found in i7/i5. Have tried editing power plan from control panel, but there's no use.
ACarmona_Intel
Hello Jacalyn,
To help me further identify the problem and offer you a solution, kindly provide the following details:
  • To confirm, does this issue only happen with Python? And when did the issue start?
  • What Python version are you using? If possible, please share the link to where you downloaded it.
  • Have you made any changes before the issue occurs?
  • What are the troubleshooting steps that you have performed? so we can avoid repeating them.
  • How about with other applications? Is the frequency normal?
  • And again to confirm, the complete model of your processor is the i9-10990K?
We look forward to your response!
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Hello Jacalyn,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Jacalyn,
We are checking in with you, as we have not heard any response from you.
Carmona A.
Intel Customer Support Technician
ACarmona_Intel
Hello Jacalyn,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
