17446 Discussions
Microcontroller high performance
CollinsBH
We are looking for a new microcontroller to support a high performance inertial measurement unit that can meeting the following parameter metrics:
Parameter
Current uP
Minimum Desirable
EEPROM
512Bytes
512Bytes
(Optional as we could use FLASH but this is slower and will need the data to be copied into RAM at powerup)
FLASH
8KB
32KB
RAM
1KB
8KB
In System Programming
Yes
Required
External clock
16MHz
56MHz via PLL
Watchdog Timer
1
1
SPI
2
2
Digital lines
23 (interrupt generating)
4 (interrupt generating)
Timers
2
2
AtoD
1 (8 channel)
1 (optional)
Temperature range
-40 to +125 Deg C
-40 to +125 Deg C
Size
3.027 x 2.77mm
4.6 x 3.9mm
ALU
8Bit Mult, Add, Sub + Logic
16bit Mult, Add, Sub + Logic
Floating point would be great!!!
DMA
0
4 (Optional)
Voltage
4.5 to 5.5v
3.3 v
Current
16mA Max at 15MHz
16mA
Questions: Understand volume, lead times, size, wafer, etc.
DeividA_Intel
Hello CollinsBH,
Thank you for posting on the Intel® communities. I understand that you need some information related to a microcontroller.
1. Why do you need this information?
2. Are you working for a company? If so, can you provide the name of the company?
3. Are you working on a project?
4. Can you provide more information about this project?
Deivid A.
CollinsBH
1. We are developing a new product to improve a gyro sensor for a new market
2. Collins aerospace part of RTX (Raytheon Technologies)
3. Yes - see 1
4. not really; basically High Performance but small, also needs to be sold as wafers so that we can put them in a container with limited room; see size in previous list (4.6 x 3.9mm)
5. we will needs lots of them 10k+
Brian (Engineering Manager)
DeividA_Intel
Hello CollinsBH,
Thank you for the information provided
I will proceed to check the issue internally to check if I can get the information or if there is a proper line of support for this request and post back soon with more details.
Deivid A.
DeividA_Intel
Hello CollinsBH,
I would like to let you know that we have a specific line of support for this kind of issue, it is called the Intel Developer Zone. There you will receive the appropriate support on this and other concerns you may have related to this product.
Here you will find the links to access the website and the community forums:
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
