17048 Diskussionen
Motherboard for Xeon L5638
Mitarbeiter
2.762Aufrufe
Hello Community!
Today i have a very special question to all of you. I recieved a Xeon L5638 from a friend - the CPU itself was a replacement-part for one of his Lenovo C20 workstations. But the Problem: The CPU is not supportet by any motherboards on the german IT-Market.
I found some information that the X58-Chipset - also the 5520 Chipset - does support this Xeon as well. Also the Asus P6T-Series is well known to support the Xeon L5638.
Now the Questions:
- Is there any hope that the Xeon L5638 is running in a Asus P6T WS Professional?
- Are there any well known boards who are supporting the L5638?
I hope you will help me soon.
1 Lösung
FGonz6
Neuer Beitragender III
1.540Aufrufe
Hello Julian,
Based on the compatible products for this processor below you can find the link of server stations designed to run with this unit
http://ark.intel.com/products/48766/Intel-Xeon-Processor-L5638-12M-Cache-2_00-GHz-5_86-GTs-Intel-QPI http://ark.intel.com/products/48766/Intel-Xeon-Processor-L5638-12M-Cache-2_00-GHz-5_86-GTs-Intel-QPI
In regards of the motherboards listed above; our suggestion will be contacting the manufacturer itself to check on compatibility.
Lösung in ursprünglichem Beitrag anzeigen
2 Antworten
FGonz6
1.541Aufrufe
Hello Julian,
Mitarbeiter
1.540Aufrufe
Hey,
i´ve just recieved a Gigabyte EX58-UD3R and the Xeon L5638 worked well after a BIOS-Update. Also some MSI-OEM-Thing out of a Medion PC (Germany) was working well. I think that a lot of X58-Boards will Support the CPU.
Antworten
