16883 Discussions
My CPU fan spin for 1 second but then stop even when my CPU temp gross to 90-100 centigrade.
KAham
My CPU : intel core i5-8400
n_scott_pearson
Yea, I agree with Al. This feels like it is either a configuration issue or a hardware problem. First, check the configuration of the fan speed control in BIOS Setup to make sure that the configuration is valid. If it is, then you need to look into whether there is a hardware issue with the cooling solution.
AlHill
What is the model number of your desktop?
Have you tried a new power supply?
Have you checked you cooling system and cleaned your heat sink?
Doc
KAham
n_scott_pearson
