16962 Discussions
NUC11TNBi7 BIOS Update available?
SteveR2
Hi all,
Thought it would be a good idea to see if my NUC11 had a bios update available.
Not found on here on INTEL, went to ASUS and found similar ones but not a precise match.
Does anyone know if the nuc11tnbi7 running bios TNTGL357.0070.2022.1028.1209 requires updating?
Above details from running dmidecode.
The PC case is labeled SBNUC11TNHi7000.
Many thanks
S
n_scott_pearson
You have BIOS 70. The latest is BIOS 78. Here is download link for this update: https://dlcdnets.asus.com/pub/ASUS/NUC/NUC_11_Pro_Kit/TNTGL357.0078.zip?model=NUC11TNHI7. Inside this ZIP file, in subfolder TNTGL357.0078\One click BIOS Flash for Windows, you will find the executable for installing this BIOS starting in the Windows environment.
Hope this helps,
n_scott_pearson
Hope this helps,
SteveR2
Thanks Scott, I tried the link, it worked  well. Tried installing it but it said I needed to install 071 first. So I modified your link to point to the 071, flashed that then the 078 and all is well.
Many thanks
S.
Bordoni75
I apologize for intruding on this thread.s, but I'm having the same problem locating any new BIOS updates.
From the Intel® Driver & Support Assistant tool I detect the following characteristics of my device:
Product Code SBNUC11TNH17000
Regulatory model NUC11TNH
Manufacturer Intel Corporation
Model NUC11TNBi7
Version M11895-403
BIOS Version TNTGL357.0077.2024.0508.1703
Date 2024-05-08
Could you tell me where I can find the new BIOS?
Thanks in advance.
Federico
pressed_for_time
Valued Contributor II
NUC11TNBi7 is the board number, the NUC is the the NUC11TNHI7 (that's i7 not 17) model. ASUS is providing support for it at this web page address .
See graphic below.
SteveR2
n_scott_pearson
Where in general should you look? Well, for starters, you should be looking on the Asus site. Asus has taken over all support. You won't find anything on the Intel site any longer.
You want to start on this page: https://www.asus.com/us/support/download-center/. Type in all or part of 'NUC11TNHi7' and then select from the pick list provided. Then, on the right side the the page, you will select 'Drivers & Tools' and, once the new page fully opens, select 'BIOS & FIRMWARE'. Oddly enough, the one BIOS listed is totally wrong for your NUC (you don't have a vPro processor or supporting hardware). You'll thus want to click on the See all Downloads entry below the box and see every version offered. The subsequently displayed list of BIOSs, ignoring that incorrect entry at the top, are yours to choose from. I am seeing entries for BIOSs 74 - 77.
Hope this helps,
