17506 Discussions
Need Help on CPU Instability
Dhanesh9397
I have a laptop with Intel Core i9 14900HX CPU and have faced stability issue 2 months ago. I did research many laptop consumer globally are facing with this issue as well.
I experiences games / apps crashes during high load or shader compilation with the following error:
1. "Access Violation" 0x000005 with NvGPUComp64.dll, especially during game background shader caching
2. BSOD CLOCK_WATCHDOG_TIMEOUT
I have contacted laptop manufacturer on this issue, and they are aware of 13th gen and 14th gen Intel Core CPU instability issue, and have replaced the mainboard (CPU + GPU) as my device still covered under warranty. Currently, I am not experiencing any issues after Mainboard (CPU + GPU) replacement. However, I am concern on about potential future occurrences for this issue as other users reported that they have done mainboard swap for over 3 times due to same CPU related issue. The current BIOS in my system is latest with old microcode patch 0x129.
The main bring up of this matter is to highlight the following:
1. Suspect 13th and 14th Gen Intel Core Mobile HX CPU are also likely affected with instability issue (based on my device issue and global users reports)
2. Laptop manufacturer are not align with Intel on latest delivery on microcode patches (0x132) via BIOS update.
Appreciate for any advice / help from your team about this, as I receive poor outcome from any I feedbacks to manufacturer support team to contain this problem.
JeanetteC_Intel
Hello Dhanesh9397,
Thank you for posting in Intel Communities and for
I want to acknowledge your concerns regarding the stability issues you encountered, including the access violations and BSOD errors. I'm glad to hear that the mainboard replacement has resolved the immediate issues for your system.
Regarding the 13th and 14th Gen processor instability, I'd like to clarify Intel's current position: Based on our analysis of the reported Intel® Core™ 13th and 14th Gen desktop processor instability issues, Intel has determined that mobile products are not exposed to the same issue. However, I understand your concerns given your experience and the reports you've mentioned from other users.
Given the specific details you've provided about your HX-series processor and the symptoms you experienced, I will further check on this matter. This will help ensure we have a complete understanding of any potential issues that may affect mobile processors. I will share an update with you once our investigation is complete and additional information becomes available.
Thank you for taking the time to report this issue and for your patience as we look into this matter further.
JeanetteC.
Dhanesh9397
Hi Intel Support Team,
Thanks for the reply. I would like to point out that I have did some testing on my own and document some valuable logs and shared to Manufacturer community support before the warranty support. Therefore, I would like to share the details to your team as well.
Refer to the link for my post to manufacturer community forum. At the end of my post, you will find the attached zip files for the crashes and logs.
https://community.acer.com/en/discussion/731025/random-games-crashes-and-bsod-on-phn16-72-attributed-by-intel-core-i9-14900hx-instability
Hope this will help your team further.
JeanetteC_Intel
Hello Dhanesh9397,
Thank you for reaching out and sharing your detailed testing documentation and logs from the Acer community forum. I appreciate the time and effort you've put into documenting these issues. However, I'd like to share some important information regarding Intel® Core™ 13th and 14th Gen processor instability issues:
Based on Intel's comprehensive analysis of reported instability issues, mobile products are not exposed to the same Vmin Shift Instability issue that affects certain desktop processors. This is documented in our official community post: https://community.intel.com/t5/Mobile-and-Desktop-Processors/Intel-Core-13-14th-Gen-Instability-Update-Future-Products/td-p/1627440
Unaffected Products Include:
  • Intel Core 13th and 14th Gen mobile processors (including HX-series processors like your i9-14900HX)
  • 12th Gen Intel Core desktop and mobile processors
  • Intel Core 13th and 14th Gen i5 (non-K) & i3 desktop processors
  • Intel Xeon processors
  • Intel Core Ultra (Series 1) processors
While your i9-14900HX is not affected by the known Vmin Shift issue, the crashes and BSODs you're experiencing still warrant investigation. I'll review the logs and crash data you've provided in your Acer forum post to help identify the root cause of these stability issues.
Thank you again for the comprehensive documentation - it will help us better understand what might be causing these problems with your system. I'll post an update once it is available.
JeanetteC.
JeanetteC_Intel
Hello Dhanesh9397,
Here's the final update that I can share regarding your concerns and again, based on the publicly available link below:
Given that this concerns a laptop processor that's integrated directly into the motherboard, we recommend reaching out to Acer directly for specialized technical support and warranty services tailored to your specific system configuration.
Important System Maintenance Steps:
  • Update your BIOS firmware to the most current version available
  • Configure BIOS settings to Intel default parameters
  • Review Acer's support website for the latest BIOS release notes and updates
Please note that Intel is actively working with OEM partners, including Acer, to develop and validate BIOS updates for systems currently experiencing issues.
Kindly check the following important details below:
  • Intel publishes specifications and recommendations based on extensive design, validation, and testing of our products. Intel regularly provides these specifications to all partners. Intel will continue to work with its partners to encourage them to adopt BIOS default settings that match Intel Default Setting profiles.
  • Based on analysis of the reported Intel® Core™ 13th and 14th Gen desktop processor instability issues, Intel has determined that mobile products are not exposed to the same issue.
  • Intel has not identified any instances of the Vmin Shift instability issue relating to Intel® Core™ 13th/14th Gen HX processors. The symptoms being reported with 13th/14th generation processors – which include OS and application hangs and crashes – are common symptoms that can stem from a broad range of potential software and hardware issues.
  • Intel recommends users adhere to the relevant Intel Default Settings for their Intel Core 13th and/or 14th Gen desktop processors, and ensure they are running with the latest BIOS for their systems. Users can check their system/motherboard manufacturer’s website and/or the Intel Product Compatibility Tool to see the latest BIOS versions for their Intel Core 13th and/or 14th Gen-powered desktop systems: https://compatibleproducts.intel.com/.
  • Customers experiencing instability symptoms on 13th and 14th Gen desktop processors should contact their system manufacturer, or in the case of a boxed processor, please contact Intel Customer Support.
I will proceed in closing this thread now. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
