17293 Discussions
New processor from RMA ,how to keep it from degrading until microcode update ?
Robot101010
Hi all ,as per the title .What is the best way for me to protect/stop degradation of this new processor until the new update ? It is an i7 14700k ,should I run it at PL1 and PL2 220 wats and lower the amps to 250 ?
Dan0987
New Contributor II
In that case, in addition to lowering AC_LL and putting a negative offset, I would also lower the turbo ratio just to be extra safe.
someguyhavework
Are you still experiencing instability issue even after RMA? I think the best way to do is to set it into intel default settings while microcode is not officially released apart from that... I think some of the board manufacturer has this update in their websites... Mines work so far no issue before using this rmaed cpu
Dan0987
New Contributor II
Setting the IA VR Voltage Limit to a reasonable value is probably the best you can do until the microcode is released. For more about this, check out Buildzoid's videos:
1. https://www.youtube.com/watch?v=2G-Y0yDSfeA
2. https://www.youtube.com/watch?v=P7TBEiygGNg
Robot101010
I have an MSI motherboard atm so I am waiting for them to update the bios to have some of those settings ,thanks for the links .
Dan0987
New Contributor II
