Not quite sure if this is the correct board, but I am becoming desperate now.
I have a Intel NUC that I am trying to instal Windows 10 2021 LTSC on, but when running the Windows setup, i dont see any available HDD's. I do see the HDD in the BIOS but not when running the Windows installer.
I tried downloading the RTS setup and extracting the drivers and loading them on a USB, but apparently they do not contain any valid drivers. I am using a Transcend SSD370S 256GB 2.5" SSD, its connected to the SATA port of the NUC. I am not sure what the problem is.
I also updated the BIOS but it didn't change anything, still no HDD.
NUC S/N: G6Jy82800BKS
SA: J67992-401
Provide the nuc model number, not the serial number.
Are you trying to install in legacy bios, or uefi?
[AI is the same as snake-oil]
