Part number help!
MrMrD
I have two boxes of BGA cpu that I thought were the same but now when I look they have different endings what does this mean? I cant see anything online about it.
PN1: FH8070304289531 SRKTD
PN2: FH8070304289531 SRM86
Are they the same CPU? What do the different endings mean?
AlHill
I suspect your first number, SRKTD, is incorrect.  Please re-check.
[If you find any Intel driver you might need, download and save it now.]
MrMrD
What do you mean incorrect? a misprinted label?
AlHill
Hmmm...  The Spec code SRKTD does not show up in the database.
The ordering code is the same for both processors:  FH8070304289531
One of the moderators will have to confirm.
AlHill
By the way, that ordering code is:
https://ark.intel.com/content/www/us/en/ark/products/230380/intel-atom-x6214re-processor-1-5m-cache-1-40-ghz.html
MrMrD
Yes the X6214RE is the cpu I am attempting to buy with the "PN: FH8070304289531 SRM86". The label I posted is on a factory sealed box bought from an official intel partner so I dont want to open it as I will not be able to return it opened.
Do you think the parts inside this box are the X6214RE?
AlHill
No idea.  You will have to wait for a moderator to confirm the spec code.  But, since that spec code does not exist on the product sheet, I would not be opening the box.
pressed_for_time
Valued Contributor III
I have found an online source that says these are embedded processors with these specs
FH8070304289531SRKTD is an Intel Atom x6202RE Processor (1.5M Cache, 1.00 GHz) FC-BGA16C, Tray.
FH8070304289531SRM86 is an Intel Atom x6214RE Processor (1.5M Cache, 1.40 GHz) FC-BGA16C, Tray.
This would make them part of the Elkhart Lake range.  The specs for the x6214RE check out but the x6202RE is not listed by Intel. It may be a typo for the x6212RE which is a 1.5M Cache, 1.20 GHz part or for the x6200FE which is a 1.5M Cache, 1.00 GHz processor.
AlHill
@pressed_for_time   Did you find "SRKTD"?  It does not show up in ark.
pressed_for_time
There is an Intel dealer that lists these CPUs and the SRKTD is the end section of a product code, so part of the ordering system. Why a different ordering code is shown elsewhere I do not know.
