17541 Discussions
Pentium processor upgrade
Present processor PentiumD 830 3 Mz. Considering upgrading to Pentium DC E6500 or 6600.. Will I see a significant change,or would I have to go to a Core 2 Duo lots more bucks.
Adolfo_S_Intel2
I would recommend contacting the motherboard manufacturer for them to provide you a list of fully supported processors for your system.
Keep in mind that the performance of the system do not depend only on the processor, but on the rest of the hardware configuration.
For more buying recommendations I would suggest contacting an Authorized Intel(R) Distributor.
You can find a list of Authorized Intel(R) Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
Adolfo_S_Intel2
I am using an ASUS P5N-E SLI MB. ASUS says it will support any LGA775 processor. The main difference I see is a faster FSB from 800 to 1066 and support for VT if necessary.
Is there anyone that has done such an upgrade
Adolfo_S_Intel2
Please check this link for a list of supported processors for your motherboard:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
As long as the processor is listed there, ti will work.
If you need more deatiled buying recommendations, please contact an Authorized Intel(R) Distributor.
As I said my MB will handle any socket 775 processor according to ASUS.
My main interest if there will be a significant performance increase.
Adolfo_S_Intel2
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
You can compare the 2 processors here:
http://ark.intel.com/Compare.aspx?ids=42805,27250,41447,41316,
But personally I do not see much of a difference in performance.
Thanks, but the Pentium D 830 which I am trying to upgrade from was not in the comparison
