17147 Discussions
Please check your Processor Thermal Solution
POxen
I just updated IntelProcessor Diagnostic Tool 64bit to the latest version and one test is failing.
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Temperature Monitor Stopped
I've never seen this error before.
Of course, I did not run the test with the older version of the tool prior to upgrading. My question is, has the test changed so that it's more sensitive or do I really have an issue and if so, specifically, what do I do about it?
My "rig" is about 6 years old.
Phil
Amy_C_Intel
Hello, PhilO:
Please provide us with the following information;
KDubo
I also installed the Intel Processor Diagnostic Tool (Revision 3.0.0.25.W.MP) and unexpectedly received a failed temperature test immediately after the test began. There are no stability problems at all when the CPU runs different applications at 100% load. The processor I am using is a Pentium 4 662 which has Thermal Monitoring Technologies according to the following link to specifications:
http://ark.intel.com/products/27486/Intel-Pentium-4-Processor-662-supporting-HT-Technology-2M-Cache-3_60-GHz-800-MHz-FSB?q=pentium%204%20662 Intel® Pentium® 4 Processor 662 supporting HT Technology (2M Cache, 3.60 GHz, 800 MHz FSB) Specifications
The motherboard model is Gigabyte GA-8ANXP-D. The BIOS settings indicate that Thermal Monitoring 2 is enabled.
Not all of the Pentium 4 processors have Thermal Monitoring Technologies. Perhaps the diagnostic tool is not running the temperature test correctly because of confusion about which models have Thermal Monitoring. Please help solve this problem I am having with the Intel Processor Diagnostic Tool:
Here is the file TESTRESULTS.TXT from the Intel Processor Diagnostic Tool:
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 3/24/2016 12:34:44 AM
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Thu Mar 24 00:34:47 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Pentium(R) 4 CPU 3.60GHz
End Time: Thu Mar 24 00:34:47 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Thu Mar 24 00:34:48 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Mar 24 00:34:48 2016
Temperature Test
Start Time: Thu Mar 24 00:34:49 2016
Test Result - FAIL
Expected: Greater than 1 degrees below max
Received: 0 degrees below max
End Time: Thu Mar 24 00:34:49 2016
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
System Information
Processor Name: Intel(R) Pentium(R) 4 CPU 3.60GHz
Processor Information: Intel64 Family 15 Model 4 Stepping 10
Number of Physical Cores: 1
Number of Logical Cores: 2
Installed System Memory: 3 GB
Operating System: Microsoft Windows 7 Professional 64-bit
Graphics Information: NVIDIA GeForce 8600 GT
System Product: 8ANXP-D
System BIOS: F2
--- IPDT64 - End Time: 3/24/2016 12:34:49 AM
--- IPDT64 - Result: Fail
POxen
Hi Amy,
  1. Home built system.
  2. i7-950 3.06 Quad Core CPU and an GIGABYTE GA-EX58-UD5 motherboard
  3. Windows 7
  4. Yes, version 3.0.0.25 64 bit
  5. Typically, it does not crash.
  6. Results file:
--- IPDT64 - Start Time: 3/25/2016 7:25:26 AM
Processor 1
Start Time: Fri Mar 25 07:25:26 2016
Test Result - PASS
End Time: Fri Mar 25 07:25:26 2016
Temperature Test
Test Result - PASS
Received: 2 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Expected CPU Frequency: 3.07
Detected CPU Frequency: 3.49783
Expected Base Clock: 133.33
Detected Base Clock: 134.532
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Fri Mar 25 07:25:31 2016
Total Time: seconds: 5
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Fri Mar 25 07:25:31 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 331.2
Error: 0
--- Floating Point Test Passed!!!---
End Time: Fri Mar 25 07:25:33 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Fri Mar 25 07:25:33 2016
Test Result - PASS
Operation Per Second: 3.98747e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Fri Mar 25 07:25:35 2016
Cache Test
Start Time: Fri Mar 25 07:25:35 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> No
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> No ---> No Test Required
PCLMULQDQ - Polys Carry-Less Multiply Supported --> No ---> No Test Required
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
No AVX AES PCLMULQDQ Tests required
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 12.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sli...
Amy_C_Intel
I have noticed that your processor is overclocked, note the following
Please enter the BIOS, set the default values and run the test one more time.
POxen
Amy,
I never overclocked it, used it as it came out of the box. Also I just ran the test again and it passed this time. This is odd, isn't it?
--- IPDT64 - Start Time: 3/25/2016 12:43:12 PM
Processor 1
Start Time: Fri Mar 25 12:43:12 2016
Test Result - PASS
End Time: Fri Mar 25 12:43:12 2016
Temperature Test
Test Result - PASS
Received: 7 degrees below max
End Time: Fri Mar 25 12:43:13 2016
Total Time: seconds: 1
Start Time: Fri Mar 25 12:43:13 2016
Test Result - PASS
CPU Frequency Test
Test Result - PASS
Detected CPU Frequency: 5.43968
Detected Base Clock: 135.992
End Time: Fri Mar 25 12:43:14 2016
Floating Point Test
Start Time: Fri Mar 25 12:43:15 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 345.6
Error: 0
End Time: Fri Mar 25 12:43:17 2016
Start Time: Fri Mar 25 12:43:17 2016
Test Result - PASS
Operation Per Second: 4.65205e+006
Error: 0
End Time: Fri Mar 25 12:43:19 2016
Cache Test
Start Time: Fri Mar 25 12:43:19 2016
Test Result - PASS
MMXSSE Test
Test Result - PASS
--- MMX SSE ---
AVX Test
Test Result - PASS
IMC Test
Test Result - PASS
Memory Allocated.
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
PCH Test
Module Version: 1.0.9.64b.W
Test Result...
Amy_C_Intel
PhilO, note the following, the CPU Frequency is still too high;
The highest you are supposed to get with this processor is 3.33 and that value is the max turbo frequency. It seems that something in your motherboard configuration is overclocking the processor. Since you already loaded the defaults and this still persists I would recommend contacting http://www.gigabyte.com/support-downloads/support-downloads.aspx GIGABYTE - Support in order to obtain more feedback.
Here you can check the specifications for http://ark.intel.com/products/37150/Intel-Core-i7-950-Processor-8M-Cache-3_06-GHz-4_80-GTs-Intel-QPI?q=Intel%C2%AE%20Core%E2%84%A2%20i7-950%20Processor%20(8M%20Cache,%203.06%20GHz,%204.80%20GT/s%20Intel%C2%AE%20QPI) Intel® Core™ i7-950 Processor (8M Cache, 3.06 GHz, 4.80 GT/s Intel® QPI) Specifications.
POxen
Well, I just ran the tests again and the detected CPU frequency is only 3.09837 (see test results below).
I have not changed a thing in the BIOS. I am running the same version of your dx tool. I think there is a bug in your software.
Phil
--- IPDT64 - Start Time: 3/31/2016 6:21:54 AM
Processor 1
Start Time: Thu Mar 31 06:21:54 2016
Test Result - PASS
End Time: Thu Mar 31 06:21:54 2016
Temperature Test
Test Result - PASS
End Time: Thu Mar 31 06:21:55 2016
Start Time: Thu Mar 31 06:21:55 2016
Test Result - PASS
CPU Frequency Test
Test Result - PASS
Detected CPU Frequency: 3.09837
Detected Base Clock: 134.712
End Time: Thu Mar 31 06:21:57 2016
Floating Point Test
Start Time: Thu Mar 31 06:21:57 2016
Test Result - PASS
Error: 0
End Time: Thu Mar 31 06:21:59 2016
Start Time: Thu Mar 31 06:21:59 2016
Test Result - PASS
Error: 0
End Time: Thu Mar 31 06:22:01 2016
Cache Test
Start Time: Thu Mar 31 06:22:01 2016
Test Result - PASS
MMXSSE Test
Test Result - PASS
--- MMX SSE ---
AVX Test
Test Result - PASS
IMC Test
Test Result - PASS
Memory Allocated.
Memory Deallocated.
PCH Test
Test Result - Config Mismatch
Platform Controller Hub Test not supported current chipset.
Skipping Platform Controller Hub Test.
End Time: Thu Mar 31 06:22:02 2016
IGD Module Test
Start Time: Thu Mar 31 06:22:02 2016
Test Result: ...
Amy_C_Intel
I have been running some tests with the Intel® Processor Diagnostic Tool and the tool behaves as expected. At this stage, I would recommend contacting http://www.gigabyte.com/support-downloads/support-downloads.aspx GIGABYTE - Support since it looks like something in your motherboard configuration is overclocking the processor.
