17158 Discussions
Poor power efficency with B760 and active Full Speed USB devices (again)
MN10
Here are already other threads but apparently no one really looks into it, so I start another one. Here you can find other threads with same/similar problems:
https://community.intel.com/t5/Processors/Poor-power-efficiency-with-B660-B760-boards-and-active-Full/td-p/1565137
https://community.intel.com/t5/Processors/High-power-consumption-when-using-USB1-1-serial-devices-under/td-p/1516435
The description is similar. When a Full-Speed USB device is connected the power consumption rises over a level that should not be possible.
My setup:
Gigabyte Aorus B760 Pro DDR4
Intel i5 14500
Problematic device:
SONOFF Zigbee 3.0 USB Dongle
Without the USB device I have a consumtion of ~20W in idle. When the device is connected i have ~35W in idle. So apparently my USB device uses 15W. How is that possible?
I used the exact same USB devices with the same OS (Debian) with an older Z270 Board and an 7th Generation Intel processor.  With this setup I couldn't even measure the difference. The power consumption was ~20W without as well ~20W with connected device.
Something is severely wrong with either the chipset or the processors. A lot of people have these problems.
Mich1
I hope they finally will come with some explanation.
There are tens of people who complained on this community about this problem. I think Intel should come with a good answer about this problem. With older chipsets there was never a problem. Problems started with 12/13th gen B660/B670 chipsets (Not sure of Q chipsets are also affected).
Something from the USB ports is keeping the CPU / Chipset awake and therefor your computer is using a lot more power
This was my conclusion posted earlier:
Conclusion so far:
1) A serial and/or communication USB device will mess up the CPU power states completely.
2) This is perceived by multiple users on different types of brands with B660 or B670 chipset.
3) This is independent off Operating system.
4) With a PCI-X USB card i can reach C6 package state (with same Z-Wave stick, instead of C2 directly on the motherboard).
MN10
Another interesting thing is that when I insert the USB device the power goes up from 22W to 36W. But when I remove the device then it stays at 36W. I have to reboot the computer to get back to 22W. So the CPU is not able to go to lower C-state than C2.
Dan0987
Interesting, indeed. In my case, the CPU goes into a deeper C state without a problem when I suspend or remove the 12 Mbits USB devices. By the way, can you please paste the output of the usb-devices command.
Girofox
You can watch what happens with package C-states with HWinfo. When even one device is inserted in any back panel USB port, the C state usage in percent drops immediately.
What is interesting is that this seems to only happen when an USB device is in Full Speed mode (this is like USB 1.1).  Most mice and wireless keyboard dongles use USB 1.1 only despite sometimes even supporting High Speed (USB 2.0 standard, 480 MBit/s).
Again, when an USB 3.0 capable USB flash drive is inserted in any USB port, the C state usage doesn't change at all. This is on my Asus Proart B760 D4 and should be the case on similar motherboard with the same chipset.
This can easily be verified by usbtreeview (by Uwe Sieber). You can see any ports and devices, including the maximum and current transfer speed.
The stuck in C2 state seems like an issue with the package demotion, undemotion behavior. Maybe the usb port or the whole usb hub where multiple usb ports are connected gets stuck in a weird state. What happens when you eject the usb device via usbtreeview?
Dan0987
Yes, I have noticed that too. Here's my thread: https://community.intel.com/t5/Processors/Poor-power-efficiency-with-B660-B760-boards-and-active-Full/td-p/1565137/
It is a pity that we all have faulty USB 1.1 devices {wink wink}
Our senior engineers have already conducted an intensive investigation into our case, and according to them, the problem is not related to the processor or the chipset. In regards to that, we recommend that you contact your USB manufacturers.
Girofox
First of all i don't want to open another thread for the same issue, so forgive my long answer. I hope it is still helpful!
The whole USB C state issue appears both in Linux and Windows, so it seems like a hardware problem, not driver or software related.
Your ~ 20 W idle power consumptions sounds really nice.
The best I got was ~ 32 W in Linux, ~ 35 W in Windows but fluctuating between 32 to 38 W. But my GPU always uses a minimum of around 10 W at idle, even when not utilized at all. So that means 22 W in best case for me for all other components.
I don't know how efficient are my PSU and the internal voltage regulators on that low power consumption though. Cannot say where the 22 W are "wasted" exactly. CPU Package shows less than 5 W on idle, got even down to 3 W according HWinfo. NVMe drives can easly get much lower than 1 W power consumption too when idle. I have one HDD always spinning though. This can easily be 1 to 5 W probably. Cannot see DRAM power either. Each PCIE Slot itself can waste 1 W when something is inserted too. The PCH Chipset itself needs power too, probably ~ 1 W ballpark.
My setup is very similar but CPU is older:
Asus B760 ProArt D4 (DDR4)
Intel i9 12900 K
Nvidia GTX 1060
Problematic devices (running at USB 1.1 aka "full speed" according usbtreeview
Logitech Wireless Dongle for keyboard
Roccat Kone XTD mouse
Problematic usb ports:
All back panel ports (USB 2 and 3)
I have two USB 3.1 front panel ports which are fine. I can connect everything there, even mouse and keyboard, and power consumption is unaffected.
On the motherboard i have Intel AX 210 PCIE card where the Bluetooth side is connected via USB directly to the USB 2.0 motherboard pins. Again, no problem with that USB connection regarding power consumption.
Here is the rest of my kind of thread
Intro
C states are really important for laptops, especially with Modern Standby. While many desktop users don't care much about C states, they can lower RAM temperature and interact with ASPM (power saving) of various components like NVMe, Network Cards etc..
Latency issues are very rare because of mechanisms like undemotion/demotion of C states. Core parking affects latency more.
Sometimes there is a drastic difference in total watts from wall adapter when CPU is in Package C6 state or only C2/C3. The Package C states interacts with ASPM over PCI express and directly affect DRAM power consumption too. Even the voltage regulator and power phases to CPU can get more efficient with lower Package C states.
For example my 12900 K uses only 5 Watts when not moving mouse, while browsing or typing in Word only uses less than 10 Watts. The whole computer stays under 50 Watts as long as GPU doesn't go into highest power mode. Chipset temperature is only 40 C. No performance loss measurable. This is despite low utilization of Package C6 state.
Some Bios settings needed to be adjusted, like Native ASPM set to disabled, PCIE Clock Gating set to enabled, and all other ASPM related settings manually at maximum possible value (L1, Enabled). This is easily possible on Asus, but on other vendors some settings may be hidden or missing at all. In ideal case the OS should fully control ASPM but this doesn't always work properly with older hardware like some GPUs.
Issue: USB ports affecting C states
Normally USB devices connected to ports should not affect Package C states when idle. Example: an USB drive inserted but not accessed via explorer / virus scan.
When an mouse (especially 1000 Hz or higher) is connected, moving the cursors causes interrupts which can lower Package C state usage. The effect should be minimal because on modern USB host controllers these are MSI interrupts (whole other topic too big to explain here). Basically this means these MSI interrupts don't "interrupt" the whole computer anymore but are handled smartly via CPU an can be routed to unused cores.
When you dont move the cursor, the mouse doesn't send any data to computer and doesn't cause MSI interrupts. So the Package C state usage should be unaffected.
The problem on chipset B760 (and similar) motherboards:
USB devices like many mice or keyboards operating in slower Full Speed mode (USB 1.x) seems to hinder Package C state usage, even when idle. This at least affects all USB back panel ports as long as they appear as USB hubs in device manager. The front USB ports usually are connected directly to host controller and don't affect C states. In device manager the connected devices appear under Generic USB hubs.
Preparation
For testing the affect of connected USB devices and overall usage of Package C states, you need some software and correct Bios settings.
Software prequisites
  • HWinfo64
  • usbtreeview (by Uwe Siebert, not the older version from Windows WDK)
Bios settings (mostly Asus)
Without the correct Bios settings you won't even get Package C3 if you are unlucky. To get at least C6 you need ASPM settings on.
Intel: Under ASPM everything needs to be selected, no setting at Auto.
  • Turn on PCI Express Native Power Management.
  • Native ASPM disabled
    (In my case i get Package C6 only when Native ASPM disabled)
  • Under the various other subsettings choose Enabled and L1 if possible.
    L0s is not enough. L0sL1 sometimes causes WHEA errors on some devices.
  • PCI Express Clock Gating must be on!
Testing
You can watch what happens with Package C-states with HWinfo. You don't need to close every program in Task Manager, just be sure no audio is playing and CPU utilization is very low. Wait for a minute and watch the values, don't move the mouse at all! Every Package C state residency are the key values here to watch
The values like CPU Package power, System Agent power and Rest-of-Chip (DRAM mostly) power are directly affected by Package C states. But other components on motherboard are directly or indirectly affected by Package C states too which don't show up in HWinfo. Ideally you have an wall outlet adapter to measure power consumption. Less than 40 W for whole computer on idle with monitor on is very good. I once got 32 W with high usage of Package C6 state. For a desktop computer with an i9 CPU and 4K 60 Hz display this is probably the lowest consumption i can get while idle. My GPU uses 10 W at idle though, so that means roughly 22 W for the rest.
First of all i disconnected all usb devices at back panel and monitored HWinfo a minute at least. Then i connected the wireless keyboard to front port, confirming that the Package C state usage quickly recovery to the previous value. Finally i took a screenshot.
Nothing connected at any back panel USB ports, only Bluetooth and Aura LED over USB internally
The Package C6 residency is around 65 percent, while C2 and C3 are almost unused. This is a good sign that C states work properly.
My 12900 K doesn't support Package C7 state. The next lower states are Package C8 and C10 are supported too but i don't know how to even get there, maybe you need Modern Standby and physically disconnected Nvidia GPU (?)
This is from the 12th Generation Intel® Core™ Processors Datasheet, Volume 1 of 2:
So it seems i am out of luck, when i don't even get lower than C7 Core state (neccesary for Package C8). But nonetheless the step from Package C3 to C6 is significant enough according to the datasheet for 12th gen Intel. I couldn't find datasheets for C states relating 13th or 14th Intel yet.
Another interesting fact is that Package C2 and C3 cannot be requested by Software, while Package C6 and lower can. So when Package C2 and C3 have high utilization while C6 has none or low utilization, this must be hardware related by motherboard because of the USB hubs itself.
Next we check what happens when a mouse or/and keyboard is connected via USB at any back panel port.
Lower Package C state residency when device connected back panel USB port
When even one device like mouse or keyboard is inserted in any back panel USB port, the C state usage in percent drops immediately. This is when the devices operates in slower full speed mode only. Sadly I don't have an mouse which operates in high speed mode for testing.
Mouse and wireless keyboard dongle connected at any back panel USB ports
I hardly get 30 percent Package C6. Definitely much worse than before. The usage of Package C2 is much higher. The Core C states usage is always deep but don't matter much because to get sub 5 Watts you need definitely at least Package C6.
For comparison:
When nothing is connected at back usb port I get 65 percent Package C6 residency while package C2/C3 almost not used. And USB 2 or 3 flash drive can be connected though without negative effect, as long as the device operated in High Speed mode. So the shallow states C2 and C3 are mostly skipped which is a more efficient way.
Common observation
Again, when an USB 3.0 capable USB flash drive is inserted in any USB port, the C state usage doesn't change at all. This is on my Asus B760 ProArt D4 and should affect similar motherboard with the same chipset. Maybe even all Asus motherboards?
Setup which affects Package C state residency
The back and front panel USB ports are all driven by Intel USB 3.20 xHCI Host Controller. But the most important difference is that the back panel ports are grouped into three separate USB hubs (Genesys Logic USB 2.0, ASMedia USB 2.1 and ASMedia USB 3.0).
USB hubs (back panel ports) marked orange, front panel device (directly connected to Host controller) marked blue
The Logitech device is connected to Generic USB 2.1 hub (back panel USB 2.0 port), this is the wireless keyboard dongle. The Roccat device is my mouse, and while it supports High Speed, it only operates in Full Speed (proably enough for 125 up to 1000 Hz polling rate). I don't know how to force an USB device into maximum possible speed as a workaround.
I don't have any third party driver installed for mouse and keyboard. Both work without issues and with all functionality.
When one device (old Taiwan OEM usb drive, High speed capable) is attached to any of the front ports, it doesn't appear under a USB hub. The same for Aura LED Controller und Bluetooth. These devices don't affect the C states either, probably because they are directly connected to Host Controller.
My theory
The whole issue only seems to happen when a device is in full speed mode, while it is connected to an USB hub in device manager / usbtreeview). This may (or may not) be an issue with wrong handles interrupts (?), very speculative though. Very weird that not moving mouse at all does lower C state usage too, so this probably contradicts an interrupt issue. LatencyMon doesn't show unusual intterupts either.
Validation
  • When connecting both mouse and wireless keyboard dongle to both front ports, C state usage is unaffected, like when no USB device is connected at all.
  • An USB 3.0 capable flash drive doesn't affect C states either, because on USB 2.0 ports it works in High Speed mode (480 MBit/s), and NOT in Full Speed mode which seems to be the issue.
  • I can reach Package C state 6 in both cases, but the C6 usage is higher when no mouse or keyboard is attached to the back.
Further testing (with a second mouse connected at front port)
  • Disabling USB devices and/or the corresponding hubs in device manager but keep them physically attached at the ports.
    Already tested, not always possible to disable in device manager.
    No effect on C states at all.
  • Eject aka "safely remove" mouse, keyboard device via usbtreeview like a flash drive.
    Already tested, yes it has the same effect as physically disconnecting.
  • Using Linux and powertop to monitor C states.
    For some reason my Nvidia GPU prevents C6, probably driver issue in Linux
Additional notes
  • Beware that Package C state usage depend on GPU too. Nvidia, Intel or AMD graphics heavily affect Package C states.
    Especially Intel Integrated Graphics can even prevent Package C6.
  • On Nvidia Package C state 6 only works for me when GPU is in a lower power mode. With HDR and 4K even some mouse movement can force GPU into highest power mode which kicks the CPU out of C6, especially on weaker GPUs for HDR (like GTX 1060).
  • Linux sometimes has problems with ASPM which can prevent Package C state 6 or lower.
AlHill
@Girofox   Seems unnecessarily long.  I think I will wait for the movie.
[If you find any Intel driver you might need, download and save it now.]
Mich1
Well at least his post is very helpfull in the discussion and is pointing straight into the problems with chipset/cpu. Your post is not adding any value into the discussion.
@GirofoxThanks for your testing and research. At the end it is the same problem we all have. But Intel is not really interested in helping us out here and are denying the problem.
just for your information. You will never reach higher then C6 when you have a PCIx card inserted in your PEG slot ( PEG is technically just "PCI Express Graphics" your 16x lane slot to the CPU ).  So it doesn't matter if your nvidia card or something else is connected in this slot. It prevents the CPU from going into deeper states.
Dan0987
Are you certain? The results from my thread were obtained when the devices were plugged into ports directly connected to the chipset. Obviously the results were worse with hubs.
Girofox
That diagram looks interesting, do you know where there is one for B760?
I'm pretty sure, that my two front ports are USB 3.0 and are directly connected to the motherboard USB 3.0 header. So no ASMedia or Genesys USB hub within the connection.
The upper Gen 3.2 one in your red square is the one connected to both my blue front ports.
The lower USB 2.0 one is connected to my Intel Bluetooth.
C state usage is definitely not affected when mouse and keyboard are connected to these front ports.
The same for my Intel Bluetooth and Aura LED Controller which are directly connected to the USB 3.2 host controller. I don't know where this host controller is on my motherboard but according to zo your diagram it should be on Chipset and not directly to the CPU.
Dan0987
Now I am baffled. I had an ASUS B760 and the results were exactly the same as with the Gigabyte B660.
The diagram above is specific to my motherboard model.
Girofox
The diagram seems to match to my motherboard at least, B660 and B760 are very similar. Looks like it is the same for all motherboard with a similar chipset.
Do you have installed any third party USB driver? Intel USB Host Controller and the hubs are running with default Windows drivers on my machine.
With Native ASPM disabled in Bios i can reach Package C6 State. The VMD Controller enabled and PCIE and Sata devices mapped under VMD (RST Raid mode) improves C6 residency further.
Dan0987
A coincidence. Cheaper boards tend to have more limited I/O.
I have not installed any third-party drivers and have no problem getting PC10. The results with every USB 1.1 device I plugged into the USB port connected directly to the chipset were almost identical.
Average of 2-minute sampling. Without any USB devices (including ARGB controllers):
C2 (pc2)	0,6%
C3 (pc3)	0,7%
C6 (pc6)	0,3%
C7 (pc7)	0,0%
C8 (pc8)	0,0%
C9 (pc9)	0,0%
C10 (pc10)	97,5%
Average of 2-minute sampling. One 12 Mbps USB device connected:
C2 (pc2)	51,4%
C3 (pc3)	1,1%
C6 (pc6)	0,1%
C7 (pc7)	0,0%
C8 (pc8)	0,1%
C9 (pc9)	0,0%
C10 (pc10)	46,2%
@Mich1 , in your case, the issue is also limited to the USB ports connected to the internal HUBs?
Girofox
@Mich1
I may have found something interesting which could be related to the whole issue.
My ASMmedia USB 2.1 Hub which powers 4 separate USB 2.1 ports at back panel of motherboard is running in High-Speed mode (USB 2.0 standard), which can be verified with USB Device Tree Viewer easily.
USB Hub Connection details
ASMedia USB 2.1 HubASMedia USB 2.1 Hub
My Roccat Kone mouse reports only Full-Speed (USB 1.1) which is different to the USB hub connection.
Mouse connected to back panel USB hub - Connection details
Mouse USB connectionMouse USB connection
When you go to the USB Hub again and scroll all the way down, you see that Link power Management is not supported. The Intel Wireless Bluetooth device shows Link power Management enabled.
USB Hub has no Link Power ManagementUSB Hub has no Link Power Management
Dan0987
The LPM works well in my case. USB devices can go in and out of low power state with no problem.
Girofox
@Dan0987
So as i understand every single USB port restricts package C10 usage? This is similar on my machine but with C6 state.
C6 drops from 70 % to barely 30 %. Doesn't matter if mouse or wirless keyboard dongle, I get the same exact result. When i move mouse slightly it still stays above 50 %.
The yellow marked USB 3.2 connector powers my two unproblematic front USB 3 ports. The blue marked USB 2 connector is connected with Intel Bluetooth, again unproblematic.
B760 motherboard layout
  • yellow: internal USB 3 connected with front ports
  • blue: internal USB 2 port (blue)
B760 Motherboard Layout (Asus)B760 Motherboard Layout (Asus)
But my two front USB ports don't exhibit this problem at all! The same as my Bluetooth controller, both are directly connected to my motherboard pin sockets. So they should go into the Chipset too. Maybe the back USB ports go into CPU directly? This seems unlikely though.
I don't know how the back ports are routed but at least a row of ports share a common power source.
Dan0987
Yes. It is important to note that the first (or one) active Full-speed USB device significantly affects package C-State. Any additional low-power Full-speed USB device, such as a mouse or keyboard, will have a marginal effect. So if any other Full-speed USB device was active during your tests (such as the AX 210's Bluetooth or the AURA controller), the assumption that the "front USB ports don't exhibit this problem" is probably incorrect. Additional overhead, when plugged into the rear ports, can be related to the third-party USB host controllers.
It would be good to set the baseline with only the necessary devices, preferably headless, without dGPU, expansion cards, LAN, Wi-Fi, AURA, etc., and in these conditions, connect one device at a time with logging active in the background.
Btw, the CPU does not have an integrated USB controller.
Wirehead
Intel, as per usual, is deaf.
Yes these are real-world problems. Simply not using the devices allows the CPU to go in lower c-states. The moment you use it - your system locks to C2 state as lowest possible.
I've tried every port as well. There's no workaround. What a mess.
Wirehead
So - the intel 600 / 700 / 800 PCH (yes, even the latest arrow lake, so I don't even have an option to get around it with a new motherboard) - all have the same errata: "Processor C-States with USB Full-speed or Low-speed Device"
With the implication "The processor may fail to enter C3 or deeper package C-States. Note: This erratum has only been observed in a synthetic environment.Wrong Intel. It's in the wild, and not just synthetic. Also not a single workaround. I've had it with Intel, goodbye, see you on team red.
