17514 Discussions
Problema con QR Code / Problem with QR Code
AlessandroP
Ho acquistato un processore i5-11400 e mi si presenta il seguente problema:
- Non vengono visualizzati correttamente i QR code (WhatsApp Desktop e altri). Essi sono incompleti e quindi non leggibili.
Cosa posso fare per risolvere il problema?
Grazie.
Alessandro
I bought an i5-11400 processor and I am presented with the following problem:
- QR codes are not displayed correctly (WhatsApp Desktop and others). They are incomplete and therefore not legible.
What can I do to solve the problem?
Thank you.
Alexander
David_G_Intel
Hello AlessandroP
Thank you for posting on the Intel️® communities. Please share with us the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
CristianSantos
Hola, también tengo un i5 11400 y presento el mismo problema, en un grupo de facebook alguien publicó que tiene ese problema, le comenté que yo también lo tengo, ambos tenemos el mismo procesador y usamos los gráficos integrados, en el momento en que escribo esto, somos 5 personas en la misma publicación con este mismo problema, todos tenemos algo en común, tenemos un i5 11400, adjunto el resultado del escaneo Intel SSU
David_G_Intel
Hello @AlessandroP
Were you able to check the previous post?
Let us know if you still need assistance.
@CristianSantos make sure your system is up to date and if the issue persists, please open a new thread with all the information.
Best regards,
David G.
David_G_Intel
David G.
superusuario
Hi, try this.
Disable  intel UHD Graphics > reload the QR code > scan QR Code > enable intel UHD Graphics
https://youtu.be/Bc1v4Up_M70
CristianSantos
