17058 Discussions
Procesor Intel Core I7CPU L620@2.00GHZ
PHV
HELLO!Can this model be upgraded with another processor?laptop GETAC300B
AlHill
It depends.  Is the current processor socketed?  If so, you will need to consult with the laptop manufacturer to determine what processors are supported by the laptop bios.
[W10 is today's XP ]
Enchrgb
重新安装你自己的那一个版本的芯片组,然后就可以安装新的了
AlHill
@Enchrgb   That is the wrong answer.  A new/different processor MUST be bios compatible.
Your answer only applies if you are installing an OS.
