17536 Discussions
Quad Node system Processor selection
RSica
In reference to R2208LT2HKC4 Quad Node server 2U system, can I install two E5-4620 processors and at a later time install two - E5-4650 processors? If this is possible, what are the negatives to a configuration with mixed processors as described above or the justification & benefits of the E5-4650? I thank you in advance for your contribution.
FGonz6
New Contributor III
Hello Ron,
As long as the processors are listed in the compatibility list of the server unit it's ok. However, to achieve a more reliable performance is recommended to use a processor with the same model and stepping to avoid any kind of problems with the microcode or even error messages.
FGonz6
New Contributor III
Hello Ron,
