17279 Discussions
Raptor Lake CPU Performance Scaling in Linux/Ubuntu/Mint
texen
I have a i5-13600K and am running Linux Mint21. I am having difficulty getting cpufrequtils and performance scaling to work properly.
CPU scaling appears to work normally with the  5.15.0-57-generic kernel but the 3d graphics isn't working.
The 6.0.0-1010-oem and 6.1.0-1004-oem kernels have the 3d graphic working fine but the scaling doesn't seem to work properly. The cur_freq generally is running at the base or max frequency even during idle cpu conditions.
The following shows the 0 P core and the 9 e core status
/sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/base_frequency:3500000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:3500000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:800000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:0
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences:default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference:balance_performance
/sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:3200000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:3200000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:<unsupported>
/sys/devices/system/cpu/cpu9/cpufreq/affected_cpus:9
/sys/devices/system/cpu/cpu9/cpufreq/base_frequency:2600000
/sys/devices/system/cpu/cpu9/cpufreq/cpuinfo_max_freq:2600000
/sys/devices/system/cpu/cpu9/cpufreq/cpuinfo_min_freq:800000
/sys/devices/system/cpu/cpu9/cpufreq/cpuinfo_transition_latency:0
/sys/devices/system/cpu/cpu9/cpufreq/energy_performance_available_preferences:default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu9/cpufreq/energy_performance_preference:balance_performance
/sys/devices/system/cpu/cpu9/cpufreq/related_cpus:9
/sys/devices/system/cpu/cpu9/cpufreq/scaling_available_governors:performance powersave
/sys/devices/system/cpu/cpu9/cpufreq/scaling_cur_freq:2599222
/sys/devices/system/cpu/cpu9/cpufreq/scaling_driver:intel_pstate
/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor:powersave
/sys/devices/system/cpu/cpu9/cpufreq/scaling_max_freq:2600000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_setspeed:<unsupported>
I had heard that Raptor Lake support would be good in the 6.1 kernel .. maybe I am using the wrong one? Anyone have any insight on this? I believe in the above environment I am setting max cpufreq with cpufrequtils at 3200 and the min cpu freq at 800.
Steven_Intel
Hello texen,
I am going to review more about this and get back to you as soon as possible.
Steven G.
texen
Some additional clarification -- In the system BIOS I have disabled 2 P cores and disabled turbo boost and set P Core max freq =3500 Mhz E core max freq = 2600Mhz
/etc/default/cpufrequtils specifies
ENABLE="true"
GOVERNOR="powersave"
MAX_SPEED="3200000"
MIN_SPEED="800000"
I run the following cpufreq program to check cpu freq every 5 secs in idle state for 10 cycles
#!/bin/bash
grep . /sys/devices/system/cpu/cpu0/cpufreq/*
echo " "
grep . /sys/devices/system/cpu/cpu9/cpufreq/*
echo `date`
for j in `seq 0 9`; do
read -t 5 -p $j
echo " Loop $j"
freq=0
for i in `seq 0 15` ; do let freq=$(grep . /sys/devices/system/cpu/cpu$i/cpufreq/scaling_cur_freq); echo "$i $freq "; done
} done
echo `date`
This is the results of the cpufreq program in the 6.1.0-1004-oem and the 5.15.0-57 kernel.
notice the much higher freq of the 6.1 kernel and the e cores are actually exceeding 2600Mhz!
kernel 6.1
cpufreq_info.sh
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference:power
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:1100170
/sys/devices/system/cpu/cpu9/cpufreq/energy_performance_preference:power
/sys/devices/system/cpu/cpu9/cpufreq/scaling_cur_freq:3500000
Wed Jan 18 05:41:27 PM CST 2023
0 Loop 0
0 3500000
1 3500000
2 1100034
3 3500000
4 1100039
5 3500000
6 1100029
7 3500000
8 799468
9 799588
10 3500000
11 3500000
12 3500000
13 3500000
14 3500000
15 3500000
1 Loop 1
0 1100047
1 3500000
2 1100054
3 3500000
4 3500000
5 1100070
6 1100057
7 1102001
8 3500000
9 799840
10 3500000
11 3500000
12 3500000
13 3500000
14 3500000
15 3500000
2 Loop 2
0 1100026
1 3500000
2 1100364
3 3500000
4 3500000
5 1100419
6 1100022
7 3500000
8 799800
9 3500000
10 3500000
11 799832
12 3500000
13 3500000
14 3500000
15 3500000
3 Loop 3
0 1070170
1 3500000
2 1100005
3 3500000
4 1100020
5 3500000
6 1100043
7 3500000
8 799900
9 3500000
10 799739
11 3500000
12 3500000
13 3500000
14 3500000
15 3500000
4 Loop 4
0 1100010
1 3500000
2 1100017
3 3500000
4 1100344
5 3500000
6 1100000
7 3500000
8 799617
9 3500000
10 3500000
11 3500000
12 3500000
13 3500000
14 3500000
15 3500000
5 Loop 5
0 1100023
1 3500000
2 1100008
3 3500000
4 1100063
5 3500000
6 1100045
7 3500000
8 3500000
9 799933
10 3500000
11 3500000
12 3500000
13 3500000
14 3500000
15 3500000
6 Loop 6
0 1100017
1 3500000
2 3500000
3 1100016
4 1100000
5 3500000
6 1100033
7 3500000
8 800151
9 3500000
10 3500000
11 3500000
12 3500000
13 3500000
14 800033
15 3500000
7 Loop 7
0 3500000
1 3500000
2 1100008
3 3500000
4 1100019
5 3500000
6 1100033
7 3500000
8 3500000
9 800096
10 3500000
11 3500000
12 3500000
13 3500000
14 800384
15 3500000
8 Loop 8
0 3500000
1 3500000
2 1100073
3 3500000
4 1100015
5 3500000
6 1100020
7 3500000
8 802828
9 3500000
10 3500000
11 3500000
12 3500000
13 3500000
14 800215
15 3500000
9 Loop 9
0 1100067
1 3500000
2 1100000
3 3500000
4 1100039
5 3500000
6 1100060
7 3500000
8 3500000
9 800000
10 3500000
11 3500000
12 3500000
13 3500000
14 799491
15 800093
Wed Jan 18 05:42:17 PM CST 2023
kernel 5.15.0-57
/sys/devices/system/cpu/cpu0/cpufreq/base_frequency:2600000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:2600000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:1093944
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:2600000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_cur_freq:900052
Thu Jan 19 07:46:05 PM CST 2023
0 Loop 0
0 1094307
1 1101083
2 1100055
3 1100672
4 1094365
5 1098951
6 1097575
7 1101593
8 900008
9 901344
10 899494
11 899944
12 900000
13 900085
14 899949
15 900000
1 Loop 1
0 1100011
1 1101151
2 1100066
3 1100109
4 1100014
5 1100770
6 1098738
7 1100881
8 899995
9 899653
10 899253
11 899899
12 900023
13 899827
14 899957
15 899915
2 Loop 2
0 1100012
1 1101615
2 1100066
3 1100084
4 1100041
5 1101779
6 1099042
7 1100902
8 900033
9 900434
10 900491
11 899247
12 899511
13 901230
14 900035
15 900952
3 Loop 3
0 1100014
1 1100964
2 1100034
3 1101175
4 1100016
5 1101702
6 1099816
7 1096968
8 900024
9 898932
10 899931
11 899763
12 900684
13 899968
14 899805
15 899411
4 Loop 4
0 1094399
1 1101087
2 1096194
3 1103426
4 1100014
5 1100053
6 1100011
7 1100129
8 900010
9 899246
10 899302
11 899993
12 898506
13 899435
14 899250
15 900492
5 Loop 5
0 1100011
1 1101215
2 1099060
3 1100603
4 1100016
5 1101214
6 1100015
7 1100076
8 900010
9 900026
10 899856
11 900244
12 899846
13 899759
14 899952
15 900029
6 Loop 6
0 1060126
1 1101729
2 1099807
3 1100071
4 1100010
5 1100042
6 1100020
7 1100747
8 900032
9 899299
10 900198
11 900103
12 901895
13 899872
14 897970
15 900587
7 Loop 7
0 1090553
1 1099082
2 1100029
3 1100838
4 1100023
5 1101654
6 1100024
7 1100927
8 899991
9 899969
10 900146
11 900081
12 899676
13 899970
14 900388
15 899861
8 Loop 8
0 1100053
1 1101128
2 1100010
3 1100042
4 1100027
5 1101984
6 1100026
7 1102397
8 899983
9 899520
10 901363
11 899874
12 898391
13 901206
14 899981
15 900015
9 Loop 9
0 1100048
1 1101273
2 1099352
3 1101000
4 1100003
5 1101153
6 1100031
7 1101042
8 899848
9 900234
10 900125
11 900024
12 900228
13 899643
14 899901
15 899963
Thu Jan 19 07:46:55 PM CST 2023
Steven_Intel
Hello texen,
In order to continue with the assistance, please download the Intel® System Support Utility for Linux (https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html) and attach the file to your reply.
Steven G.
texen
Here you go Steven ..
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
y
attached is the output
Steven_Intel
Many thanks for your response.
I will keep working on this and get back to you once I have an update.
Steven G.
Steven_Intel
Hello texen,
Thank you for your patience on this matter.
Since this issue only occurs on some specific kernels, it means this is not a CPU issue, but a Kernel/Linux issue. Our best recommendation is to go to the Linux forums/communities and get further assistance/information.
Steven G.
texen
So you are saying Intel does not write linux kernel code to support it's processors? News to me.
The reason I am submitting this issue here is I did not find any thing relevant in other Linux forums/communities.
But if this is of no interest to Intel to improve it's processor support in Linux well good luck with that...
