17506 Discussions
SM Bus Controller & PCI problem
Kins
Hello.
I built a new computer this week-end with a brand new I7 12700k.
I have in my device manager (win 11) problems with drivers for the PCI Bus Controller and PCI.
I have been trying to find a way to make it right but when I'm trying to use the Intel logiciel for the PCI Bus Controller I have a 0x00004e24 error...
What can I do?
Thanx
David_G_Intel
Hello Kins
Thank you for posting on the Intel️® communities. Please share more information with us for a better understanding:
  • Did this start after you installed Windows 11?
  • Can you share screenshots of the errors?
  • Did you reinstall the OS?
  • Are the two devices showing the same error?
  • Intel® System Support Utility (Intel® SSU) results
David G
Kins
Thank you for your answer David but like always, I did manage to fix it with after cleaning my drivers.
Just one PCI device that windows 11 doesn't recogniseto go. I'll make another Topic if I have a problem with this one.
Thank you.
David_G_Intel
We are glad to know you found a solution, since the thread is solved we will close it now.
David G
