17506 Discussions
Significant decrease in my processor speed
Readn
He
13th Gen Intel(R) Core(TM) i7-1355U 1.70 GHz
RAM 16,0 Go
OS 64 bits, x64
ASUS ZENBOOK
For the past few days my processor speed measured with a benchmark program cpu bounded is unstable two to four times lower than nominal speed.
My computer is one year old.
Intel processor Diagnostic tool does not detect failure. Neither RAM control.
CPU1
Frequency Check
Module Version: 1.0.7.64b.W
Start Time: Thu Feb 6 16:08:53 2025
Test Result - NO COMPARE OPTION USED
Processor Name: 13th Gen Intel(R) Core(TM) i7-1355U
Measured Processor Frequency: 2.609165
End Time: Thu Feb 6 16:08:54 2025
Total Time: in seconds: 1
Here is performance report of task manager.
Thanks for your advice.
Readn
Hi @Earl_Intel
I reset Windows 11 and it worked. For now I have the original performances back.
A previous attempt to update the bios was unsuccessful.
Thank you for your contribution.
Earl_Intel
Hi Readn,
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • What Benchmarking application you're using?
  • May I know what is the exact model of your ASUS ZenBook laptop?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Readn
Hi @Earl_Intel
I compared my computer with a similar computer exposed at my seller. It is an ASUS vivobook with the same Intel Core i7 1355U processor.
I use C# program solving strategy games as Score four or Othello I've written to benchmark computer. This perfectly runs.
Here is result for my computer and shop's computer.
A ratio of 1 to 3. Note that the result is unstable on my computer.
I noticed a noticeable difference in frequency between the two computers when my program is running.
Next post SSU scan report.
Readn
Hi @Earl_Intel
I am considering updating the computer’s BIOS with ASUS tools. Is this a good idea?
Beginning of SSU report
# SSU Scan Informatio
Scan Info:
Version:"3.0.0.2"
Date:"02/07/2025"
Time:"00:00:21.7891339"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. UX5304VA.304 , 05/16/2023"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"13th Gen Intel(R) Core(TM) i7-1355U , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.5"
Sound Card:"Technologie Intel® Smart Sound pour audio USB"
Sound Card:"Realtek High Definition Audio"
Sound Card:"Technologie Intel® Smart Sound pour microphones numériques"
Sound Card:"Technologie Intel® Smart Sound pour audio Bluetooth®"
System Manufacturer:"ASUSTeK COMPUTER INC."
System Model:"Zenbook S 13 UX5304VA_UX5304VA"
System SKU:"Not Available"
System Type:"x64-based PC"
Readn
Readn
Hi @Earl_Intel
Readn
Hi @Earl_Intel
I use C# programs solving strategy game such as score four I've written for benchmark windows computer.
My intention is to BIOS update and if not work to have my computer repaired.
Here Intel report
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"02/07/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Iris(R) Xe Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(R) Xe Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Xe+Graphics"
CoInstallers:"oem222.inf,iRPLPD_w10_DS,Internal,Intel(R) Iris(R) Xe Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"07/24/2024 02:00"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_c2201cfb126f0796\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"32.0.101.5768"
INF:"oem222.inf"
INF Section:"iRPLPD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c2201cfb126f0796\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c2201cfb126f0796\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c2201cfb126f0796\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c2201cfb126f0796\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_A7A1&SUBSYS_16D31043&REV_04\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"60 Hz"
Resolution:"2880 X 1800"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(R) Xe Graphics Family"
- "Memory"
Physical Memory (Available):"3,75 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15,62 GB"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller0-ChannelA"
Configured Clock Speed:"5200 MHz"
Configured Voltage:"500 millivolts"
Data Width:"16 bits"
Form Factor:"Unknown"
Interleave Position:"First position"
Manufacturer:"SK Hynix"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"H9JCNNNCP3MLYR-N6E"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller1-ChannelA"
Interleave Position:"Second position"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller0-ChannelB"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller1-ChannelB"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller0-ChannelC"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller1-ChannelC"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller0-ChannelD"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller1-ChannelD"
Type:"Synchronous"
- "Motherboard"
BIOS:"UX5304VA.304, _ASUS_ - 1072009"
Caption:"Carte-mère"
Chipset:"Not Available"
Date:"05/16/2023 02:00"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"UX5304VA"
Serial Number:"R730NBCV00WC9NMB"
Status:"OK"
Version:"1.0"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "ASIX AX88772A USB2.0 to Fast Ethernet Adapter"
Caption:"ASIX AX88772A USB2.0 to Fast Ethernet Adapter"
CoInstallers:"Not Available"
Default IP Gateway:"192.168.1.1;fe80::1a1e:78ff:fe4b:f142"
DHCP Enabled:"Yes"
DHCP Lease Expires:"02/08/2025 07:08"
DHCP Lease Obtained:"02/07/2025 07:08"
DHCP Server:"192.168.1.1"
Driver:"ax88772.sys"
Driver Date:"01/19/2007 12:00"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\netax88772.inf_amd64_8cf5f634aa308898\ax88772.sys"
Driver Provider:"Microsoft"
Driver Version:"3.18.19.1213"
Index:"0014"
INF:"netax88772.inf"
INF Section:"AX88772A.Ndi"
Installed:"Yes"
IP Address:"192.168.1.27;fe80::b969:e2fd:61f8:fd6e;2a01:cb00:dd0:d600:a531:3c23:73ba:d86;2a01:cb00:dd0:d600:7c5:3260:ae59:45c4"
IP Subnet:"255.255.255.0;64;128;64"
Last Reset:"02/06/2025 11:40"
MAC Address:"00:0E:C6:12:3D:99"
Manufacturer:"ASIX"
Net Connection ID:"Ethernet 2"
NetCfgInstanceId:"{B467269B-1A99-4E94-9376-8A63EA9AACB3}"
PNP Device ID:"USB\VID_0B95&PID_772A\000E9C"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: Yes"
Power Management Supported:"No"
Product Type:"ASIX AX88772A USB2.0 to Fast Ethernet Adapter"
Service Name:"AX88772"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Client pour les réseaux Microsoft:
Nested Network Virtualization:
Partage de fichiers et imprimantes Réseaux Microsoft:
Pilote de pont:
Pilote de protocole LLDP Microsoft:
Pilote E/S de mappage de découverte de topologie de la couche de liaison:
Planificateur de paquets QoS:
Protocole Internet version 4 (TCP/IPv4):
Protocole Internet version 6 (TCP/IPv6):
Répondeur de découverte de la topologie de la couche de liaison:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00"
Driver Path:"C:\WINDOWS\system32\drivers\bthpan.sys"
Driver Version:"10.0.26100.1150"
Index:"0001"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
MAC Address:"10:A5:1D:7A:7D:8E"
Manufacturer:"Microsoft"
Net Connection ID:"Connexion réseau Bluetooth"
NetCfgInstanceId:"{03B7102C-76B0-4C41-8C12-0299359E9430}"
PNP Device ID:"BTH\MS_BTHPAN\6&1F5AE0E4&0&2"
Power Management (Wake on Magic Packet):"Not Available"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
- "Intel(R) Wi-Fi 6E AX211 160MHz"
Access Point:
Authentication:
- "Caption":"Intel(R) Wi-Fi 6E AX211 160MHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6E+AX211+160MHz"
Channel:
Cipher:
Connection Mode:
DHCP Enabled:"Yes"
Driver:"Netwtw14.sys"
Driver Date:"10/03/2024 12:00"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\netwtw6e.inf_amd64_5433b0cac0a04d0e\Netwtw14.sys"
Driver Provider:"Intel"
Driver Version:"23.40.0.4"
Index:"0000"
INF:"oem95.inf"
INF Section:"Install_GEN_SLR_GfP2_211_AX_6G_2x2_WinT"
Installed:"Yes"
MAC Address:"10:A5:1D:7A:7D:8A"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{C1C763F2-F596-494A-AA14-A516F51F00DD}"
Network Name:
Network Type:
PNP Device ID:"PCI\VEN_8086&DEV_51F1&SUBSYS_00948086&REV_01\3&11583659&0&A3"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Wi-Fi 6E AX211 160MHz"
Profile:
Radio Type:
Receive Rate:
Service Name:"Netwtw14"
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Pilote de pont:
- "Settings"
*DeviceSleepOnDisconnect:Veille à la déconnexion WoWLAN:"Désactivé(e) (0)"
*PacketCoalescing:Fusion des paquets:"Activé(e) (1)"
*PMARPOffload:Délestage ARP pour WoWLAN:"Activé(e) (1)"
*PMNSOffload:Délestage NS pour WoWLAN:"Activé(e) (1)"
*PMWiFiRekeyOffload:Régénération des clés GTK pour WoWLAN:"Activé(e) (1)"
*WakeOnMagicPacket:Wake on Magic Packet:"Activé(e) (1)"
*WakeOnPattern:Correspondance au modèle WOL:"Activé(e) (1)"
ChannelWidth24:Largeur de canal pour 2,4 GHz:"Auto (1)"
ChannelWidth52:Largeur de canal pour 5 GHz:"Auto (1)"
ChannelWidth6:Largeur de canal pour 6 GHz:"Auto (1)"
CtsToItself:Protection en mode mixte:"RTS/CTS activée (0)"
FatChannelIntolerant:Incompatible avec canaux de 40 MHz:"Désactivé(e) (0)"
IbssTxPower:Puissance de transmission:"5. Max. (100)"
IEEE11nMode:Mode sans fil 802.11n/ac/ax:"4. 802.11ax (3)"
Is6GhzBandSupported:Bande ultra élevée (6 GHz):"Activé(e) (1)"
MIMOPowerSaveMode:MIMO – Mode économie d'énergie:"SMPS auto (0)"
RoamAggressiveness:Agressivité de l’itinérance:"3. Moyenne (2)"
RoamingPreferredBandType:Bande privilégiée:"1. Aucune préférence (0)"
ThroughputBoosterEnabled:Multiplicateur de débit:"Désactivé(e) (0)"
uAPSDSupport:Assistance U-APSD:"Désactivé(e) (0)"
WirelessMode:Mode sans fil 802.11a/b/g:"6. Dual Band 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Mozilla Firefox, Google Chrome,133.0, Internet Explorer,11.1882, Microsoft Edge,132.0"
Locale:"France"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Famille"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"9,50 GB"
Physical Memory (Available):"3,77 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.26100 Build 26100"
Virtual Memory (Available):"10,10 GB"
Virtual Memory (Total):"25,12 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5050094:"Update [1/30/2025]"
KB5050108:"Update [1/30/2025]"
KB5050577:"Update [1/29/2025]"
- "Processor"
- "13th Gen Intel(R) Core(TM) i7-1355U"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 186 Stepping 3"
- "Chipset Name":"13th Gen Intel(R) Core(TM) i7-1355U"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=13th+Gen++Core+i7+1355U"
CPU Speed:"1,7 GHz"
Current Voltage:"1.8 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00"
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Version:"10.0.26100.3037"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"10 x 96 KB"
Level 2 Cache:"10 x 6656 KB"
Level 3 Cache:"12 MB"
Load:"15%"
Manufacturer:"GenuineIntel"
Model:"186"
Name:"13th Gen Intel(R) Core(TM) i7-1355U"
Number of Cores:"10"
Number of Cores Enabled:"10"
Number of Logical Processors:"12"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000B06A3"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- " MS SCSI Disk Device"
Capablities:"Random Access, Supports Writing"
Caption:"MS SCSI Disk Device"
Cylinder - Total:"38913"
Description:"Lecteur de disque"
Error Code:"Device is working properly"
Firmware Revision:"0"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Lecteurs de disque standard)"
Model:"MS SCSI Disk Device"
Partitions:"1"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_&PROD_MS\6&A026109&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Sectors - Per Track:"63"
Sectors - Total:"625137345"
Serial Number:"C55987654321"
Size – Available:"46,17 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"9922815"
- "D:"
Availability:"Not Available"
Caption:"D:"
Compression Method:"Not Compressed"
Description:"Disque monté local"
File System:"NTFS"
Serial Number:"B8799EB0"
Size – Available:"46,1655349731445 GB"
Volume Dirty:"No"
- "JetFlash Transcend 64GB USB Device"
Capablities:"Random Access, Supports Writing, Supports Removable Media"
Caption:"JetFlash Transcend 64GB USB Device"
Cylinder - Total:"7681"
Firmware Revision:"1100"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"USB"
Model:"JetFlash Transcend 64GB USB Device"
Partitions:"1"
Physical Sector Size:"512"
PNP Device ID:"USBSTOR\DISK&VEN_JETFLASH&PROD_TRANSCEND_64GB&REV_1100\01XUOA8OYF0E8NI0&0"
Sectors - Total:"123395265"
Serial Number:"AA00000000000489"
Size – Available:"5,29 GB"
Status:"OK"
Tracks - Total:"1958655"
- "E:"
Caption:"E:"
Description:"Disque amovible"
File System:"FAT32"
Serial Number:"EB225BBB"
Size – Available:"5,28900146484375 GB"
Volume Dirty:"Yes"
- "NVMe INTEL SSDPEKNW010T8"
- "Caption":"NVMe INTEL SSDPEKNW010T8"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=NVMe+INTEL+SSDPEKNW010T8"
Cylinder - Total:"124519"
- "Firmware Revision":"004C"
Link:"http://www.intel.com/content/www/us/en/support/solid-state-drives/000017245.html?wapkw=ssd+firmware"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Model:"NVMe INTEL SSDPEKNW010T8"
Partitions:"4"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_INTEL_SSDPEKNW01\4&10B9E979&0&020000"
SCSI Bus:"2"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Total:"2000397735"
Serial Number:"0000_0000_0100_0000_E4D2_5CF9_9236_5501."
Size – Available:"504,61 GB"
SMART Attributes:"Self-Test: 0 minutes, OK, Short Self-Test: 0 minutes, OK"
Status:"OK"
Tracks - Total:"31752345"
- "C:"
Caption:"C:"
File System:"NTFS"
Serial Number:"045C188D"
Size – Available:"504,616008758545 GB"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"0"
0x09 Power-On Hours:9432:"0"
0x0C Power Cycle Count:143:"0"
0xAE Power-off Retract Count:5:"0"
0xBB Uncorrectable Error Count:0:"0"
0xBE Temperature - Current:34° C:"0"
0xBE Temperature - Highest:Not Available:"0"
0xBE Temperature - Lowest:Not Available:"23"
0xE8 Available Reserved Space:0:"10"
0xF1 Total LBAs Written:4297,42 TB:"0"
0xF2 Total LBAs Read:1535,95 TB:"0"
...#SSU#...
Readn
Scan Info:
Version:"3.0.0.2"
Date:"02/07/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Display"
Bits Per Pixel:"32"
INF:"oem222.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "BANK 0"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 0"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Type:"Synchronous"
- "Motherboard"
Product:"UX5304VA"
Status:"OK"
Version:"1.0"
- "Networking"
DHCP Enabled:"Yes"
Index:"0014"
Installed:"Yes"
Manufacturer:"ASIX"
Status:"Enabled"
Pilote de pont:
- "Settings"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0001"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
Access Point:
Authentication:
Channel:
Cipher:
Connection Mode:
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem95.inf"
Installed:"Yes"
Network Name:
Network Type:
Profile:
Radio Type:
Receive Rate:
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Pilote de pont:
- "Settings"
Locale:"France"
- "Processor"
Architecture:"x64"
CPU Speed:"1,7 GHz"
FPO:"Not Available"
INF:"cpu.inf"
Load:"15%"
Model:"186"
Status:"OK"
Stepping:"3"
- "Storage"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"1"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "E:"
Caption:"E:"
File System:"FAT32"
Volume Dirty:"Yes"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"4"
SCSI Bus:"2"
SCSI LUN:"0"
SCSI Port:"0"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
...#SSU#...
VonM_Intel
Hello, Readn.
I’m glad to hear that resetting Windows 11 helped restore the original performance! It’s great that the issue seems to be resolved for now.
Thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, I will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel
Von M.
