Single Sign On error
BarryM
Sorry if this is the wrong place for this but I can't find anywhere I can raise such an issue. I am having problems with my i5 13600K CPU and want to raise a support request but am unable to because I constantly receive a single sign on error when trying to do so.
Any help would be appreciated.
Alberto_R_Intel
BarryM, Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
What is the problem with your Intel® processor?
When did you purchase it?
What is the model of the motherboard?
Did you build the computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Albert R.
BarryM
Hi Albert,
Here is the information. I have also reached out to support to resolve my account issue.
I can no longer run the system with the Turbo Boost feature enabled, if enabled the system blue screens immediately on attempting to start Windows. This happens when attempting to boot from the Windows installation media as well. I can access the BIOS menu but nothing else. Once Turbo boost is disabled the system runs stable.
February 2023
ASRock Z690 Phantom Gaming 4
Yes
Yes
June 14th 2023
No, the system had been working fine previously
Home
Barry
Alberto_R_Intel
Hi BarryM, Thank you very much for providing that information and the SSU report.
Based on the SSU report all, the components are properly installed, recognized, and fully compatible with your processor.
In order to rule out a possible hardware problem with the processor, please install ad run the Intel® processor diagnostics tool, it does an overall test on the unit and if it passes the test it means it is working properly:
https://www.intel.com/content/www/us/en/download/15951/intel-processor-diagnostic-tool.html?wapkw=ipdt
Additionally, we recommend to get in contact directly with ASRock Support to reset the BIOS to default values and then test the system that way. And also in order to make sure the latest BIOS version is currently installed in your machine or if necessary, to gather the instructions o how to update it:
https://www.asrock.com/support/
In the following link, you will find additional details about Intel® Turbo Boost Technology 2.0 which is the version supported by your processor:
https://www.intel.com/content/www/us/en/support/articles/000007359/processors/intel-core-processors.html
Once you get the chance, please let us know the results.
Albert R.
Alberto_R_Intel
Hello BarryM, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello BarryM, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
