16939 Discussions
Software ecc memory model (register) ideas.
colminzu2
Regards Intel corprlation.
My name is colminzu2. Thank you your coporation.
Present for corporation we have ideas.
exsample one graphical software regster.
| [here position(x,y)] <= fx1_regsiter_AX( "32byte_data")={ return( "__asm( "*")__; ); }
|          |<logical graphical buslines.
|        [here position(x,y)] <= fx2_register_BX( "32byte_data")={ return("__asm("*")__; }
(y) DX CX MMX FMA or security system.
(x)----------------------------------------------------------------------
Connect to geometory points [here positioins].
into software ECC memory model or Software L1 L2 L3 software cachee and Big ZFS ARC filesystem cache( software emulation on graphic giometry emulation ).
software geometry system.
AX---- |             Soft geometory core                          |
             |            and geometry logical bus                  |----------CX
BX-----|                   i386                                                 |----------DX
Virtual geometry transform connector are can we software ecc memory model?
I'm difficult english very sorry.
Thank you very mach. I'ts a fun.
Tahnk you very mach Linus tovalds.
Thank you very mach Intel corporation.
Jean_Intel
Hello colminzu2,
The ECC memory model is related to the memory modules. To have more insight and a better understanding of your issue, provide me with a more detailed description of your Idea, and information on what you are looking for. Also, I want to confirm why it is related to the processor.
Create a report using the Intel System Support Utility (Intel SSU)
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
• Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
• To save your scan: click on "Next"; then "Save."
Jean O.
Jean_Intel
Hello colminzu2,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello colminzu2,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
