17532 Discussions
Software feedback: Intel XTU - Window Timer Resolution flaw
TProw
Hey, I'm using Intel XTU and I found a flaw in the software, whenever I have the software open, even on idle, it keeps my timer set and raised to 1ms until I close the software, therefore causing a waste in power and potentially speed when the software is simply open, I see no point in having the software use a 1ms timer if all it does is update information every 1 second.
My idea is to only call TimeBeginPeriod once a stress tester or benchmark has been initialized, and call TimeEndPeriod once the benchmark/stresser is done, that way it's not unneededly keeping a raised timer resolution for no reason when the software is actually idle. (I find it a little ironic that a piece of software meant to tweak and monitor hardware for peak performance and efficiency has a efficiency flaw in itself)
Thanks !
Silvia_L_Intel1
Hello User2012, I would like to thank you for your feedback. I am going to share this information to the corresponding team.
