16903 Discussions
[Solved] Microsoft Store fails to install Intel NUC Software Studio
Dirk_Salewski
Hello all,
I recently reinstalled my gaming laptop XMG Fusion 15 (M22). Before reinstall I had a perfectly working version of the Intel NUC Software Studio, which is a discontinued product now. However, the software is still available at the Microsoft Store: https://apps.microsoft.com/detail/9nt0zdv64htc?hl=en-US&gl=US
Unfortunately it is not possible to convince the Microsoft Store to install the software.
Steps to reproduce:
  1. Install a current copy of Microsoft Windows 11
  2. Install the UniwillService that is the foundation for the functions.
  3. Open the Microsoft Store and try to install the application.
    1. This is the install screen
    2. When pressing the [Installieren] (=Install) button you can notice the "turning circle" for a fraction of a second, but nothing happens afterwards.
What I did to solve the situation:
Intel offers a guide to fix problems with apps from the Microsoft Store at https://www.intel.com/content/www/us/en/support/articles/000088290/wireless.html, which I followed to the letter. In short:
  1. Reset the Microsoft Store and its cache
  2. Ensure your machine’s Time and date are correct
  3. Remove any security or firewall applications (refers explicitly to third party software, so i left the Microsoft Defender untouched)
  4. Reregister the Microsoft Store
None of these steps was successful, the problem prevails.
Why is this a problem?
  • The software is needed to change some important settings of the laptop that are related to performance and cooling.
  • Less important but a pity nevertheless: The software is able to control the colour effects of the Laptops Keyboard and LED front bar. Reinstalling set that back to plain white (keyboard) and off (front bar).
System Specifications:
Operating SystemMicrosoft Windows 11 Home
Version 10.0.26100 Build 26100
ManufacturerSchenkerTechnologiesGmbH
System modelXMG FUSION 15 (XFU15M22)
System-SKUXFU15M22
BIOS-Version/-DateIntel Corp. KCTGL357.0051.2024.1218.1352, 18.12.2024
BaseBoard-ManufacturerIntel Corporation
BaseBoard-ProductLAPKC71F
BaseBoard-VersionM22222-403
I would be happy if someone could pick this up and point out a solution that I didn't try before.
Best regards
Dirk
Steve000
Try these additional steps:
  1. Install via PowerShell
    • Open PowerShell as admin and run:
      winget install --id 9nt0zdv64htc
  2. Check Microsoft Store Logs
    • Run: Event Viewer → Windows Logs → Application and look for errors related to Microsoft Store.
  3. Manually Install Dependencies
    • Ensure UniwillService is installed and running (services.msc).
    • Install Microsoft Visual C++ Redistributables (latest versions).
  4. Try Compatibility Mode
    • Download the AppxBundle manually (via Fiddler or external tools) and install using Add-AppxPackage.
  5. Use an Older Windows Version
    • Some apps fail on newer builds. Try a Windows 10 or earlier Windows 11 version (e.g., 22H2).
For detail guide visit at Microsoft Store fails to Install Intel NUC Software Studio? Here’s the fix
Steve000
Dirk_Salewski
Hi Steve000,
thank You very much - directly the first approach did the trick.
Best regards
Dirk
AlHill
@Steve000   Wow... that article was just published today.  What a conincidence!!  Plus, a chatgpt answer as well.
[W10 is today's XP ]
Dirk_Salewski
Thank you, AlHill, I was already angry with myself that searching the internet up and down didn't find me the same solution, but that explains it. Does not diminish my gratitude, though.
Dirk
Steve000
@AlHill I posted the article after finding the issue. Also I have not copy pasted from the ChatGPT. This is just my research and experience. If you see the community has accepted my solution. Although I am not an Intel employee but I have expertise in solving these types of problems.
