System upgrade
ScarletPhoneix
  1. PRO B660-A DDR4 Motherboard
  2. Intel Core i5-12400F Processor
  3. Corsair Vengeance RGB Pro SL 32GB (2x16GB) 3600MHz CL18 1.35V DDR4 RAM
  4. MSI GeForce RTX 4060 Ti VENTUS 3X 16G OC GDDR6 128-bit DX12 Ultimate DLSS 3 Gaming Graphics Card
  5. Kingston KC3000 PCIe 4.0 NVMe M.2 SSD – SKC3000S/1024G Black 1024GB
  6. iCUE 4000X RGB Tempered Glass Mid-Tower ATX Case
  7. Corsair iCUE H100 RGB CW-9060053-WW 240 mm Liquid CPU Cooler
With the computer I assembled using these components, especially in games, my monitor (VA panel, 165Hz, 1920x1080) outputs visuals, but the FPS stays stuck in the 150–200 FPS range and doesn’t go higher. I suspect there is a bottleneck between my processor and graphics card. I believe my graphics card should be suitable for playing AAA games as well as titles like CS2, Valorant, and GTA V.
Therefore, without changing the motherboard or RAM, I would like to ask whether I can increase my FPS simply by upgrading the CPU, and if so, which processors you would recommend. Thank you.
AlHill
You can look at the processors supported by your board, posted on the msi site:
https://www.msi.com/Motherboard/PRO-B660-A-DDR4/support#cpu
More FPS?  What is your cpu usage during your FPS test?  If you have CPU to spare, a faster processor may not help.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
