17256 Discussions
Troubleshooting my PC and i7-2600K CPU fail IPDT's PCH test. Is this the cause for fail update?
KTupm
Hello
This is my first post so sorry if this post may be out of place but I am having some issue with my PC. Recently, it's fail to boot after Windows' updates quite often. I ran the test and the CPU fail the PCH test. I was wondering if this failure may contribute to the fail updates. The test result and the screenshot is posted below.
Thank you in advance.
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 06/09/2014 12:17:06---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 66 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-2600K 3.40GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.40
Detected CPU Frequency is --> 3.40162
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
Base Clock test Pass ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 316.8
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.31663e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel(R) P67 Chipset
Chipset Stepping : B3
2 device connected to PCI Express Port 0
1 : AMD Radeon HD 5700 Series
2 : High Definition Audio Bus
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 2
1 : USB xHCI Compliant Host Controller
1 device connected to PCI Express Port 3
1 : Qualcomm Atheros AR9285 Wireless Network Adapter
1 device connected to PCI Express Port 4
1 : Standard Dual Channel PCI IDE Controller
1 device connected to PCI Express Port 5
1 device connected to PCI Express Port 7
1 : PCI standard PCI-to-PCI bridge
1 device connected to PCI Express Port 8
1 : Standard SATA AHCI Controller
--- Error while retrieving SATA Device Information from OS ---
..Platform Controller Hub Test Failed..
Platform Controller Hub Test Failed. Error while retrieving SATA Device Information from OS
Kevin_M_Intel
Hello k@rn,
Welcome to our community and I hope you find very helpful this site.
Most of the times if running the Intel® Processor Diagnostic Tool and test fail it is because there is a problem with the processor.
I recommend you updating the BIOS in your system first to the latest provided by the Computer Manufacture and then trying updating the graphics driver.
Here you can check some instructions for the installation:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Once you have done these steps, try running the Intel® Processor Diagnostic Tool again and if it fails again I recommend you contacting your local support or our chat support for possible replacement:
  1. http://WWW.Intel.com/Chat WWW.Intel.com/Chat
Kevin M
