16968 Discussions
Turbo Boost Max Technology 3.0
DRain2
Hi I have an MSI GV628RE laptop with a core I7-8750H proccessor from what i can read on here it should have the Turbo Boost Max Technology 3.0
download is there anyway i can check if it is installed and running and if it is not how do i make it run or download
Dave
n_scott_pearson
Intel Turbo Boost Max 3.0 is a feature of the Intel® Core™ i7-69xx/68xx Extreme Edition desktop processor family (i.e. the i7-6800K, i7-6850K, i7-6900K and i7-6950X). You most definitely do not have it in your (heck, in any) laptop.
DRain2
thanks but the intel site said it was on the I7-8750H chip set
n_scott_pearson
No it didn't. I am sure you've read it wrong. Show me where it says this.
DRain2
Hi as usuall cannot find it again it was in a list that was meant to be compatable with Turbo Boost Max Technology 3.0 now check somewhere else and that says it is compatable with Turbo Boost Max Technology 2.0
https://ark.intel.com/content/www/us/en/ark/products/134906/intel-core-i7-8750h-processor-9m-cache-up-to-4-10-ghz.html
Scroll down to Advanced Technologies
Does that sound right
Cheers
Dave
AndrewG_Intel
Hello DRain2
We would like to jump in to help and clarify that the information provided by n.scott.pearson is correct.
Intel® Core™ i7-8750H Processor does not support Intel® Turbo Boost Max Technology 3.0. Only Intel® Turbo Boost Technology 2.0 is supported as per Intel's Technical Specifications:
Also, the Intel® Core™ Processors supporting Intel® Turbo Boost Max 3.0 Technology can be found in the following link, which does not list the Intel® Core™ i7-8750H Processor:
https://www.intel.com/content/www/us/en/support/articles/000021587/processors.html
Also, we do not comment or endorse information published on third-party websites nor the information provided by your laptop manufacturer (OEM). For additional details regarding the technical specifications of your laptop, we recommend you to contact your OEM (MSI* support team).
Andrew G.
