Turbo Boost Monitor
After installing Norton 360 and running the tune up on my husband's ASUS laptop with i5, the original Turbo Boost monitor was no longer available. I have downloaded the new version 2.0 however, my husband is unhappy with the look of the new version on his screen. If I disable the monitor does turbo boost still continue to work? Is the monitor only to see when the turbo boost is working?
PWert
Valued Contributor I
You can disable, unpin or close the monitor. Turbo boost will not be effected.
