17509 Discussions
Unexpected Interrupt - Halting - CPU or MB Problem?
Hi.
I have the Gigabyte GA-EX58-UD4P (rev. 1.0) (BIOS beta F14o) motherboard with the Intel Core i7 920 processor. For 3 years my PC worked fine. Yesterday i conected an old USB Wireless Card to the motherboard to connect to my router for internet (http://www.level-one.de/levelone.php?page=prod&cat=7026&model=WNC-0600USB http://www.level-one.de/levelone.php?page=prod&cat=7026&model=WNC-0600USB) and windows failed to install the device with the internal drivers. So i put a usb flash with the drivers in another usb port. After 10 seconds my windows showed me a Blue Screen with some errors. (EDIT: The blue screen appeared to me before i install the drivers for the usb wireless card. I just insert the usb flash and looking the files in it in "My Computer" and after 10 sec i 've got a BSOD... I never install the drivers for the wireless card.).
So, i switched off my PC, disconnected all devices (wireless card and usb flash) and on restart the bootloader says me that the Hal.dll is missing. When i put the VISTA DVD-ROM to enter the recovery console and restart the PC, the PC sayed me that an another file is missing and i couldn't enter the setup or the recovery console. I restart again my PC with booting from CD-ROM again and the same problem happens.
I restart again my PC with the Memtest86+ CD-ROM inside and run the MemTest and the result is "Unexpected Interrupt - Halting". See the attached image for details.
Please help me, what is this problem and how it is created? How can i fix it?
Thank you very much.
P.S.:
My PC parts are:
MB: GA-EX58-UD4P (rev1.0) F14o
CPU: Intel Core i7 920 @ 2.66
RAM: OCZ 3x2GB DDR3 OCZ3X1333LV6GK
VGA: Gainward 9986 GTX285 1GB
PSU: CoolerMaster UCP 900W [RS-900-AAAA-A3]
HDD:
WD 750GB WD7502ABYS
WD 640GB WD6401AALS
WD 320GB WD3200AAKS
DVD: Sony DDU-1675S & AD-7220S
OS: Win VISTA 64bit
We would first like to mention that the BIOS seems to be a beta version and not a production/final version. Also, the description relates the issue to a driver device conflict within the Operating System and the USB device. Furthermore, if a .dll file is indicated to be missing, this means the Operating System is corrupted. Please note that in order to discard a corrupted Operating System, best option is proceeding with a fresh installation.
From the processor side, please make sure this is being properly recognized by the system and properly working. For this matter, when being able to boot into the Operating System, feel free running the Intel® Processor Diagnostic Tool to confirm it is properly working: http://www.intel.com/support/processors/sb/CS-031726.htm http://www.intel.com/support/processors/sb/CS-031726.htm
What we can recommend you is contacting your motherboard manufacturer for troubleshooting the hardware portion involved on the issue.
Karla i appreciate you for the answer.
I want to do a small edit: The blue screen appeared to me before i install the drivers for the usb wireless card. I just insert the usb flash and looking the files in it in "My Computer" and after 10sec i 've got a BSOD... I never install the drivers for the wireless card. So (i think) it can't be a driver conflict. Also, i've checked the flash for viruses on a friend's laptop after this and it's clean.
*The operatng system was fine and it can't be corrupted since i never install any drivers. The OS is about 6 months intalled and i ensure you it is clean and functional.
Also, you suggest me 2 things:
1) You suggest me to do a fresh installation. I can't do a fresh installation, because, as i said, the Windows Setup can't load either! When i boot from CD and trying to load the windows setup the system says me that an another file is missing (i don't remembrer the filename) and it can't load me the setup to do that. The only thing that can load and run from CD is the Memtest86+.
2) About the BIOS. You said me that is a beta version. I know that. The Gigabyte support forums suggest me to update to this version about 3 years ago because i had problems in compatibility with my memory. After i flash the BIOS from F3 to F14o the problems disappear and the PC worked fine for 3 years ago.. Now if you want to flash my BIOS to a newer version, i can do it only to a beta version since there is not any final version for my model: http://www.gigabyte.com/products/product-page.aspx?pid=2986# bios GIGABYTE - Motherboard - Socket 1366 - GA-EX58-UD4P (rev. 1.0).
