16893 Discussions
Upgrade to older CPU T4200
Billmc
Grandma has an old HP G60 that she will not give up. Problem is all new programs will not run on her Laptop due the the T4200 CPU. Need an upgrade to this one with the same size and pin. It is a P type.
AlHill
No upgrade will help you to run w10 or w11 with the new programs and graphics.   Take the laptop to a recycle bin.
Also, socket compatibility is NOT the only upgrade issue.
[If you find any Intel driver you might need, download and save it now.]
