17053 Discussions
Utilize single core (Application uses only single core) of i7-8550U CPU to 4.00 GHz.
DJado
I have a single core intensive application and Laptop is configured with
i7-8550U CPU.
I would like to utilize single core to the maximum of 4.00 GHz as supported by the processor.
OS is Win 10 and 16GB RAM.
How can I achieve it single core maximum performance of 4.00 GHz for this application on my laptop?
~DJ
Esteban_C_Intel
Hello DJado,
I would like to inform you that it is true that your processor (Intel® Core™ i7-8550U Processor) can support up to 4.00GHz but only at Max Turbo Frequency, and the process is done automatically.
The operation is dependent on headroom available in one or more cores. The amount of time the system spends in turbo boost mode depends on workload, environment, and platform design.
The processor must be working in the power, temperature, and specification limits of the thermal design power (TDP). This results in increased performance of both single and multithreaded applications. There is no need to install any software or application to support Intel® Turbo Boost Technology.
Esteban Ch.
A Contingent Worker at Intel
Esteban_C_Intel
Hello DJado,
Were you able to check the previous post? If you need further assistance, please let us know.
Esteban Ch.
Esteban_C_Intel
Hello DJado,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
