17160 Discussions
Voltages for i7 2600K Sandy Bridge
Hi ,
i have a 2600k and want to overclocked it , just because it's fun and these Cpu is made for it , with those unlocked multiplicator.
But i'm wonder wich voltages can i apply to him for a stable H24 settings .
Some people talk about 1.38v but i haven't see nothing from Intel about that .
I already make some benchmarks with him
http://valid.canardpc.com/show_oc.php?id=2055321 http://valid.canardpc.com/show_oc.php?id=2055321
5.33Ghz with 1.47v
He's fully Watercooled
But how much can i apply to be safe for the future for a regular Usage ?
Sorry for my bad English
Thanks for reply
Adolfo_S_Intel2
Please keep in mind that although this processor is unlocked, we do not recommend over-clocking the processor above 3.8 GHz.
This is because that is the maximum tested speed that Intel can confirm that the processor will be running at a stable behavior.
If the processor is over-clocked above 3.8 GHz, the processor will be running out of specifications, so Intel cannot guarantee that the processor will be running at a stable behavior.
Also over-clocking the processor above 3.8 GHz will void the processor warranty.
If you need information about Intel warranty policies, please check this link:
http://cache-www.intel.com/cd/00/00/05/03/50372_50372.pdf http://cache-www.intel.com/cd/00/00/05/03/50372_50372.pdf
Hi sir ,
Yes i fully understand that the garantee is not available if this processor is overclocked , but the garantee is not necessary for me
if these cpu is broken i can buy a new one .
I just want to know , wich voltage is "acceptable" for this processor .
The datasheets of other processor show the VID max exemple 0.85v to 1.45v
But i can't find the VID range for the Sandy Bridge 2600k.
Some people say 1.38v maximum , is it right ?
Adolfo_S_Intel2
The VID for this processor is 1.52 Volts
Ok
thank you for your response .
I can now overclock my Cpu safely under the maximum VID range
Thanks a lot
