17148 Discussions
What is the model of this CPU??
I have a CPU and I don't know form which series it is.
You can see the informations I have:
processor : 0 (and 1, 2, 3 the same)
vendor_id : GenuineIntel
cpu family : 15
model : 4
model name : Intel(R) Xeon(TM) CPU 2.80GHz
stepping : 10
cpu MHz : 2800.447
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe lm onstant_tsc pni monitor ds_cpl cid cx16 xtpr lahf_lm
bogomips : 5604.93
I think it is the Xeon 7030 (http://ark.intel.com/Product.aspx?id=27225&processor=7030&spec-codes=SL8UB), but I'm not sure.
Can you confirm that???
Download this utility below:
Intel® Processor Identification Utility
http://www.intel.com/support/processors/sb/CS-015477.htm http://www.intel.com/support/processors/sb/CS-015477.htm
Then Go to the link below:
http://processorfinder.intel.com/default.aspx http://processorfinder.intel.com/default.aspx
Select the Intel Xeon Family
Fill in as much information as possible and see if you can identify it. (like cpu speed, cache size, package type, bus speed)
If the sorting list is too long, you will need to remove the cpu from the system and get the SL number from the CPU itself.
All the best,
Aryan
