17248 Discussions
Why does my CPU only support 32GB RAM when it has 39 address bits?
BLohr
The following is the output of cat /proc/cpuinfo
user@localhost:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 60
model name : Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz
stepping : 3
microcode : 0x12
cpu MHz : 800.000
cache size : 3072 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid
bogomips : 6784.48
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
Now, 39 bits should get me 512GiB addressable physical memory. However, the http://ark.intel.com/products/77480/Intel-Core-i3-4130-Processor-3M-Cache-3_40-GHz Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz only supports 32GiB. Why is this? How can I reconcile this calculation?
I am not asking about the number of slots in the motherboard, maximum ram / DIMM cards etc. I am looking for how the physical bits, address lines, and the maximum amount of physical RAM fit. I understand that the mother board designer does not need to use all the the RAM that the CPU can take. But it seems that the CPU can only take 32GiB of RAM while the 39 bits physical should let it take 512GiB. Why did Intel allot 39bits physical when it could do with 35 physical bits.
Also, 48 bits should account for 256TiB of virtual address space. Is this true?
Hi lordloh,
Please let me investigate about this, as soon I get an answer I let you know.
Hellen.
Ronny_G_Intel
Hello lordloh,
Theoretically yes but there are instructions set on the processor to allow a maximum amount of memory to 32GB.
Details are available here: https://www-ssl.intel.com/content/www/us/en/processors/core/4th-gen-core-family-desktop-vol-1-datasheet.html Desktop 4th Gen Intel® Core™ Processors Datasheet, Vol. 1 page # 18
I hope this helps,
Ronny G
Hi Lordloh,
Could you please let me know if Rguevara's information helps you?
Hellen.
BLohr
I think it makes a few things clear.
My understanding is that the processor supports a certain type of DRAM technology viz. - 4Gb / DIMM. This allows a maximum of 32GiB.
I am not well versed with DRAM technology and therefore may have gaps in my understanding here. Let me know if any of these are wrong -
  • The DRAM controller in the processor supports certain kind of DRAMs
  • The DRAM controller supports a maximum of 4GiB / DIMM and supports a maximum of 8 DIMMs - thus 32GiB.
What I am not able to reconcile is that I am using a 8GB DDR3 card and have 2 of these as my MotherBoard only supports 16GB RAM. I would be grateful if someone could point me some easy to understand DRAM resource. I am trying to figure this from various pages on wikipedia.
Hi Lordloh,
Please let me investigate this.
Hellen.
Hi Lordloh,
The memory controller in the processor can handle different RAM device Technology (1Gb, 2Gb & 4Gb) with a specific DRAM organization.
Here you can get more information about:
http://www.intel.com/content/www/us/en/processors/core/4th-gen-core-family-desktop-vol-1-datasheet.html http://www.intel.com/content/www/us/en/processors/core/4th-gen-core-family-desktop-vol-1-datasheet.html
Page 19
Hellen.
Hi Lordloh,
Thought I would just check in and find out if the information provided helps you.
Hellen.
