16887 Discussions
Why is my 14900KF using excessive voltage and downclocking excessively?
Reinforcer
I received a 14900KF a few days ago and using it on an Asus Strix Z690 Gaming A motherboard with everything set at default and on auto the voltage is excessively high and clocks are downclocking from and not maintaining 5.6ghz during multithreaded workloads this is with any motherboard enhancements disabled and locked at spec 253W.
My clocks are downclocking to 5.2ghz during Cinebench when your advertised speeds say 5.6 all core and also the E cores are downclocking to 4.3ghz from 4.4 with a max temp of 65-70 so there is no thermal throttling and also the voltage is is peaking at 1.52v in Windows???
Is this chip defective?
Screenshots attached of max voltage in WIndows, Temp and low clock speeds.
Jose_Intel
Hello @Reinforcer
Thank you for posting on the Intel️® communities.
We understand you are experiencing performance issues with your Intel® Core™ i9 processor 14900KF, we will be more than happy to assist you.
Please make sure your BIOS is up to date.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the report from Intel® Processor Diagnostic Tool.
Jose B.
Jose_Intel
Hello Reinforcer
We hope you are doing fine.
Were you able to update the BIOS?
Let us know if you still need assistance by attaching the required reports.
Jose B.
Reinforcer
Yes I am already using the latest Bios for this board, The issue is the VID Voltage tables match for both P core and E core at 1.458V and this is not normal they should not match, Also the Voltage required for the E cores is unacceptably high at 1.458v, The cores are slow compared and not clocked anywhere near the Core clocks of the P cores, I feel the silicon on this chip is not right, I have sent a support request with screenshots attached.
n_scott_pearson
All of the issues that you are reporting in this latest post are either the fault of the BIOS configuration stored on the motherboard or are overides being applied by XTU. Did you load Optimal Defaults after updating the BIOS and/or after replacing the processor? You should always do so in these cases, IMHO.
Hope this helps,
Reinforcer
That is Optimized defaults in the bios I have tried it numerous times with and without XMP.
I do not have Intel XTU installed so there is nothing overiding anything.
I will attach a screenshot to show the issue.
The E cores on my 14900KF are using excessive voltage, It should be in the 1..3-1.35 range as other users are reporting in their chips, E cores should not be using this amount of voltage for low frequency cores it is resulting in an overall voltage of 1.53v in windows because the E core silicon is so poor in this chip.
See screenshot, The E core Vid is exactly the same as the P cores, I do not know how this chip got through testing.
Jose_Intel
Hello Reinforcer
Thank you for your reply.
We understand you have opened a web ticket with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you for.
Jose B.
