17153 Discussions
Why is nuc6i5syk with i5-6260u missing tsx-ni, when ARK and everywhere else says it should have it?
Why is nuc6i5syk with i5-6260u missing tsx-ni, when ARK and everywhere else says it should have it? Even Amazon lists it as having TSX-NI.
Is there some way to enable it?
Amy_C_Intel
Hello, codepilot:
How do you know that is missing?
See output from CoreInfo below, hle and rtm are missing, same with CPU-Z, HwInfo, programs that use don't work, etc.
C:\Users\root\Downloads\sysinternalssuite>coreinfo
Coreinfo v3.31 - Dump information on system CPU and memory topology
Copyright (C) 2008-2014 Mark Russinovich
Sysinternals - www.sysinternals.com
Intel(R) Core(TM) i5-6260U CPU @ 1.80GHz
Intel64 Family 6 Model 78 Stepping 3, GenuineIntel
Microcode signature: 0000006A
HTT * Hyperthreading enabled
HYPERVISOR - Hypervisor is present
VMX * Supports Intel hardware-assisted virtualization
SVM - Supports AMD hardware-assisted virtualization
X64 * Supports 64-bit mode
SMX - Supports Intel trusted execution
SKINIT - Supports AMD SKINIT
NX * Supports no-execute page protection
SMEP * Supports Supervisor Mode Execution Prevention
SMAP * Supports Supervisor Mode Access Prevention
PAGE1GB * Supports 1 GB large pages
PAE * Supports > 32-bit physical addresses
PAT * Supports Page Attribute Table
PSE * Supports 4 MB pages
PSE36 * Supports > 32-bit address 4 MB pages
PGE * Supports global bit in page tables
SS * Supports bus snooping for cache operations
VME * Supports Virtual-8086 mode
RDWRFSGSBASE * Supports direct GS/FS base access
FPU * Implements i387 floating point instructions
MMX * Supports MMX instruction set
MMXEXT - Implements AMD MMX extensions
3DNOW - Supports 3DNow! instructions
3DNOWEXT - Supports 3DNow! extension instructions
SSE * Supports Streaming SIMD Extensions
SSE2 * Supports Streaming SIMD Extensions 2
SSE3 * Supports Streaming SIMD Extensions 3
SSSE3 * Supports Supplemental SIMD Extensions 3
SSE4a - Supports Streaming SIMDR Extensions 4a
SSE4.1 * Supports Streaming SIMD Extensions 4.1
SSE4.2 * Supports Streaming SIMD Extensions 4.2
AES * Supports AES extensions
AVX * Supports AVX intruction extensions
FMA * Supports FMA extensions using YMM state
MSR * Implements RDMSR/WRMSR instructions
MTRR * Supports Memory Type Range Registers
XSAVE * Supports XSAVE/XRSTOR instructions
OSXSAVE * Supports XSETBV/XGETBV instructions
RDRAND * Supports RDRAND instruction
RDSEED * Supports RDSEED instruction
CMOV * Supports CMOVcc instruction
CLFSH * Supports CLFLUSH instruction
CX8 * Supports compare and exchange 8-byte instructions
CX16 * Supports CMPXCHG16B instruction
BMI1 * Supports bit manipulation extensions 1
BMI2 * Supports bit manipulation extensions 2
ADX * Supports ADCX/ADOX instructions
DCA - Supports prefetch from memory-mapped device
F16C * Supports half-precision instruction
FXSR * Supports FXSAVE/FXSTOR instructions
FFXSR - Supports optimized FXSAVE/FSRSTOR instruction
MONITOR * Supports MONITOR and MWAIT instructions
MOVBE * Supports MOVBE instruction
ERMSB * Supports Enhanced REP MOVSB/STOSB
PCLMULDQ * Supports PCLMULDQ instruction
POPCNT * Supports POPCNT instruction
LZCNT * Supports LZCNT instruction
SEP * Supports fast system call instructions
LAHF-SAHF * Supports LAHF/SAHF instructions in 64-bit mode
HLE - Supports Hardware Lock Elision instructions
RTM - Supports Restricted Transactional Memory instructions
DE * Supports I/O breakpoints including CR4.DE
DTES64 * Can write history of 64-bit branch addresses
DS * Implements memory-resident debug buffer
DS-CPL * Supports Debug Store feature with CPL
PCID * Supports PCIDs and settable CR4.PCIDE
INVPCID * Supports INVPCID instruction
PDCM * Supports Performance Capabilities MSR
RDTSCP * Supports RDTSCP instruction
TSC * Supports RDTSC instruction
TSC-DEADLINE * Local APIC supports one-shot deadline timer
TSC-INVARIANT * TSC runs at constant rate
xTPR * Supports disabling task priority messages
EIST * Supports Enhanced Intel Speedstep
ACPI * Implements MSR for power management
TM * Implements thermal monitor circuitry
TM2 * Implements Thermal Monitor 2 control
APIC * Implements software-accessible local APIC
x2APIC * Supports x2APIC
CNXT-ID - L1 data cache mode adaptive or BIOS
MCE * Supports Machine Check, INT18 and CR4.MCE
MCA * Implements Machine Check Architecture
PBE * Supports use of FERR# /PBE# pin
PSN - Implements 96-bit processor serial number
PREFETCHW * Supports PREFETCHW instruction
Maximum implemented CPUID leaves: 00000016 (Basic), 80000008 (Extended).
Logical to Physical Processor Map:
**-- Physical Processor 0 (Hyperthreaded)
--** Physical Processor 1 (Hyperthreaded)
Logical Processor to Socket Map:
**** Socket 0
Logical Processor to NUMA Node Map:
**** NUMA Node 0
No NUMA nodes.
Logical Processor to Cache Map:
**-- Data Cache 0, Level 1, 32 KB, Assoc 8, LineSize 64
**-- Instruction Cache 0, Level 1, 32 KB, Assoc 8, LineSize 64
**-- Unified Cache 0, Level 2, 256 KB, Assoc 4, LineSize 64
**** Unified Cache 1, Level 3, 4 MB, Assoc 16, LineSize 64
--** Data Cache 1, Level 1, 32 KB, Assoc 8, LineSize 64
--** Instruction Cache 1, Level 1, 32 KB, Assoc 8, LineSize 64
--** Unified Cache 2, Level 2, 256 KB, Assoc 4, LineSize 64
Logical Processor to Group Map:
**** Group 0
I just went to Intel ARK, it was updated, http://ark.intel.com/compare/91497,91167,91163,91156,91164,91166,91160 ARK | Compare Intel® Products. Yesterday, all of these had Iris and TSX-NI, which are the two must have items for that list. Now all but 2 have had TSX-NI removed. Can you please explain this?
I checked google's cache of i5-6260U's ARK page from Jan-31-2016, it showed TSX-NI = YES, now it currently shows NO.
Amy_C_Intel
I have sent you a private message.
RF4
Hello, can you please explain the situation to me too?
Our company works on some things where low level synchronization tricks are important. So, I have purchased new NUC6i5SYH especially for experiments with TSX-NI and performance evaluation comparing to spinlocks and some lock-free magic. Now the NUC is useless for me due to missing features. I was waiting for three generations and doubly checked the ARK before ordering to be sure that the CPU has TSX.
Another strange thing: TSX-NI is enabled for CPUs lauched in Q3'15 but disabled in ones launched in Q1'16. Maybe there is some BIOS patch enabling TSX, even if it is buggy... I just wanted to evaluate it.
Thanks a lot!
Regards, Roman
Amy_C_Intel
Hello, @roman_f:
