17500 Discussions
Windows 10 stops after error 86 with Intel(R) Dynamic Platform Thermal Framework at DELL Latitude E5470
LMuño3
Se apagó el sistema debido a un evento térmico crítico.
Hora de apagado = ‎2020‎-‎04‎-‎11T23:45:45.520818700Z
Zona térmica ACPI = Intel(R) Dynamic Platform Thermal Framework
_CRT = 373K
AlHill
That update was provided by Dell. I installed it on my laptop (E7470) and all is fine.
Contact Dell for support with their update.
Doc
LMuño3
Thank you for your review and response. Sure enough, the driver has a January 2020 update, I downloaded it from the dell page, but the error remains
https://www.dell.com/support/home/co/es/cobsdt1/drivers/DriversDetails?driverId=9HWMD
Nombre del sistema operativo:       Microsoft Windows 10 Pro
Versión del sistema operativo:       10.0.18363 N/D Compilación 18363
AlHill
You need to contact Dell regarding this issue. Or, remove the driver. Or, rollback to a checkpoint prior to you installing the driver.
Doc
