XTU help
BG207
XTU does work with 14700k will there be an update for XTU soon.
Alberto_R_Intel
BG207Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order for us to answer your question and provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Did you build it?
What is the specific problem you are seeing with the Intel® XTU tool?
Was it working fine before?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Albert R.
BG207
I built myself ,this is a Z690 ASUS hero motherboard with a I7 14000k 2 32 gig sticks of corsair dominator memory
a 4080 ASUS / NOCTUA card , air cooled 1000 w power supply ceres 500 TT case. when I turn on under volt protection in the bios
XTU loads but will not let me under volt, when i disable UVP in bios XTU will not start XTU tells me to enable it. SO what did I do, I used
the BIOS to under volt the system, its running great now lowered volts and watts temps are GREAT ALL GOOD.
THANKS FOR ALL YOUR HELP
BG207
BG207
NOT NEW , UPDATED BIOS 2803 I built myself ,this is a Z690 ASUS hero motherboard with a I7 14000k 2 32 gig sticks of corsair dominator memory  a 4080 ASUS / NOCTUA card , air cooled 1000 w power supply ceres 500 TT case. When I turn on under volt protection in the bios, XTU loads but will not let me under volt, when i disable UVP in bios XTU will not start XTU tells me to enable it. SO what did I do, I used the BIOS to under volt the system, its running great now lowered volts and watts , temps are GREAT ALL GOOD.
BG207
Alberto_R_Intel
BG207, You are very welcome, thank you very much for sharing those updates.
Perfect, excellent, it is great to hear that you were able to use the BIOS to undervolt the system, lowering volts and watts and now the temperature results are great.
Any other inquiries, do not hesitate to contact us again.
Albert R.
