hi, the vt-d is very complicate.
is there any sample code could help me to implment the dma-remapping in my system?
my processor is i7 2600.
thanks.
- Tags:
- Intel® VTVT-X
Hi watermirror,
Can you confirm if you are referring to a code to modify the DMA on the processor? I mean changing the configuration on it?
Here is some information you can find very helpful:
https://www-ssl.intel.com/content/www/us/en/intelligent-systems/intel-technology/vt-directed-io-spec.html https://www-ssl.intel.com/content/www/us/en/intelligent-systems/intel-technology/vt-directed-io-spec.html
Hi kevin,
My goal is to prevent some part of memory from being destroied by DMA access.
I have already read the
https://www-ssl.intel.com/content/www/us/en/intelligent-systems/intel-technology/vt-directed-io-spec.html Intel® Virtualization Technology for Directed I/O: Spec
But I still do not know how to start code.I can understand the table which remaped dma.
But how could I assign device to certain guest(or VM), how could I know if there any access volating the dma remaping table?
Is there any more document I should read?
I will verify this with the development team. Let me check and I will be back with more information.
Hello watermirror,
I am sorry for the delay and I appreciate your patience.
Based on the research, there is a link that contains very detail information that can help you with your task. Here is it:
https://software.intel.com/en-us/blogs/2009/02/24/step-by-step-guide-on-how-to-enable-vt-d-and-perform-direct-device-assignment/ https://software.intel.com/en-us/blogs/2009/02/24/step-by-step-guide-on-how-to-enable-vt-d-and-perform-direct-device-assignment/
With this, you should not need to do any programming. Let me know if it works.
