17158 Discussions
can't update processor :( why not... help me someone
tthom17
so i have a intel core 2 duo T5670 processor and i need to update it as i can't play any games that use Java, if you need an example minecraft but other games that i need to run in the upcoming weeks. i need to see if this is a problem i can fix and if not i can wait until september when i get a custom PC... hope someone can help ^_^-
Thomas Potter
Founder of Northern Lights productions
P.S. ignore the founder but i always put that in anything i right online that isn't a comment on something...
AlHill
Your processor is: http://ark.intel.com/products/35163/Intel-Core2-Duo-Processor-T5670-2M-Cache-1_80-GHz-800-MHz-FSB Intel® Core™2 Duo Processor T5670 (2M Cache, 1.80 GHz, 800 MHz FSB) Specifications
You do not update the processor. You may update the BIOS of your motherboard, or other device drivers.
If you are referring to updating the graphics driver, you need to provide more information, as the T5670 does not have graphics built-in.
Provide your system make and model, Operating system and revision, and any other information about your system. Then, the Intel Support Staff can help you.
Doc
Were you able to run the utility?
Allan.
