- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hello. Ever since, I bought my processor, I am experiencing this problem where after half or so hour of moderate to heavy load, my system would just freeze and I have to do a hard reset to get it back working. Initially, I thought it might be due to heating issue, so I bought an AIO which doesn't allow my cpu to go even above 50 even while gaming on max settings. However the issue still persists.
Recently, I tried to stress test my CPU using cinebench. On multicore test, it finishes the 10 min mark most of the time, sometimes it would freeze and I have to hard reset again. But whenever I try to run single core stress test, it always freezes the whole system within 2-3 minutes. I tried checking individual cores by setting the affinity in task manager to just use efficient cores and it doesn't crash when using them. But whenever I am using performance cores, the crash is always there. I am not sure what's going on... can anyone pls help? The system on idle runs smoothly for around 2 hours or so and then it would randomly freeze again and I have to repeat the same process...
Please ask if you require any log files for further assessment..
Specs:
i5 14500
ASUS prime b660M-D4
1x 16GB ram 3200mhz
Zotac Nvidia GTX 1070Ti
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Cynicalcare,
Can you try running Intel® Processor Diagnostic Tool for us to check if the processor will pass the test?
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html`
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Mike.
I ran the test and it passed it. I have attached the results below.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Cynicalcare,
Thank you for the quick reply.
Upon checking the details that you provided, you are not using a "K" processor and it passed all the test in the Processor Diagnostic tool. Let me provide gather the following details for us to proceed.
- Are you having temperature issues?
- What is the temperature readings before the system reboot?
- Is there a chance that you can perform swap test for the processor and board to isolate the issue?
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
1. Currently I am not having any temperature issues. Even during the diagnostic tool stress test, the temperature was stable around 60°C overall.
2. The reboot happens randomly. If system is left idle, most of the time it happens after 2 hours have elapsed or if I am running any benchmark or stress test it happens after I run it 2-3 times.
3. Unfortunately, I don't have a spare mobo lying around, hence I am also confused about whether it's a CPU issue or mobo issue. I checked my ram and psu to eliminate them as potential problem.
The PC would work in safe mode and I tried clean booting, removing all drivers and reinstalling them but that didn't fix it either. So I don't think it's a driver issue either
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Cynicalcare,
Thank you for the update.
You are correct, at this point it is hard to tell between the processor and the board.
That is why we recommend to perform swap test.
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Cynicalcare,
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
